SicStar.com Thread - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Companies (https://stuntride.the-nags.com/forumdisplay.php?fid=97) +--- Thread: SicStar.com Thread (/showthread.php?tid=46469) |
SicStar.com Thread - SIC Nate - 10-03-2013 ESD does not make a rear set specifically for your year, but the 05-06 rear set brackets will bolt up. With this option you would have to get an 05-08 foot brake pedal as the 09-13 are a larger diameter pivot. I have a set of these on my 2013 and BannisXtreme has them on his 2011. SicStar.com Thread - Duane S. - 10-03-2013 so change the pedal only? How the shifter side? SicStar.com Thread - SIC Nate - 10-03-2013 Shifter side is the same SicStar.com Thread - ajbsays - 10-04-2013 I have the esd rear sets on my 2013 636, and as nate said you just got to change foot brake lever... once again big thanks SIC NATE www.sicstar.com SicStar.com Thread - Duane S. - 10-05-2013 how much are they? SicStar.com Thread - SIC Nate - 10-06-2013 03-04 636 - $139 brackets only (stock pegs) 03-04 636 - $199 brackets with folding knurled pegs 05-06 (05-13) 636 - $199 with fixed shorty pegs (05-08 brake pedal needed for use on 09-13) F4i - $219 with fixed shorty pegs 03-04: ![]() 03-04 w/pegs: ![]() 05-13: ![]() F4i: ![]() All fixed peg:
SicStar.com Thread - Larse - 01-30-2014 Nate, as a heads up.. the sicstar shop homepage is not working
SicStar.com Thread - SIC Nate - 01-30-2014 I messed up the IP address yesterday. It will be up within the hour. Thanks for the heads up SicStar.com Thread - OnPoint - 12-24-2014 Congrats on the new site. On-Point performance is a supporter of Sic Nate and the Sic Shop. Love seeing the progress
