why not a 600rr? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: why not a 600rr? (/showthread.php?tid=39208) |
why not a 600rr? - GIL with 1 L - 09-20-2012 03-06 idle and computer have nothing to do with each other.messing with the air fuel wax unit will give you problems why not a 600rr? - tys0n - 09-21-2012 On a 07+ you just disconnect the VSS (vehicle speed sensor) and the wire that goes from computer to speedo...( pink/green) near the main harness for speedo plug and bam you can turn up the idle ( must have idle cable mod) Mine is steady up to 3k... after that it doesnt idle down right.. but my buddy whom mrides a 06 636 says it pulls harder than his bike on idle. why not a 600rr? - COTE - 09-21-2012 Quote:
