2003 636 Idle Problem - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 2003 636 Idle Problem (/showthread.php?tid=37517) |
2003 636 Idle Problem - Laurens - 01-12-2013 So from what i understand.. first things to check if you have an idle problem and don't think you have a head with "tuningwork" than the first things to check are; TPS Complete wire harnass? Friend of mine has the problem the bike is really slow @ getting back to 3k idle when you slow down to 800 -1000 rpm. We did some quick swap with parts of my 636 but nothing helped. 2003 636 Idle Problem - wooter - 01-13-2013 The weird thing is... this code is on my engine ![]() zx636a... Does an 2002 engine fit in a 2003 frame? And besides 2002 was carb engine right? 2003 636 Idle Problem - old man roger - 01-13-2013 There was a 2002 636 in Europe but I don't remember if it was carburated or FI. 2003 636 Idle Problem - wooter - 02-22-2013 Just swapped whole engine. Got less miles on it. Hope it works
