thermastat 636 replacement - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: thermastat 636 replacement (/showthread.php?tid=44995) |
thermastat 636 replacement - Duane S. - 11-20-2012 Well now the over flow bottle is almost empty and nothing spit out thermastat 636 replacement - old man roger - 11-20-2012 That sounds like the radiator wasn't full when the bike was hot so it pulled the fluid in from the overflow bottle as it cooled. This could be caused by air in the system or a leak. Top off the radiator and the overflow bottle and see if it runs cooler now. thermastat 636 replacement - navajowalks - 11-20-2012 I concur thermastat 636 replacement - Duane S. - 11-20-2012 yea when i get back from florida I'll put some more in and give it another shot before I go deeper into the engine.....cause my homeboy said the samething about that my res. tank is empty so I'll fill it up again thermastat 636 replacement - navajowalks - 11-20-2012 Fill your radiator first then your overflow.. thermastat 636 replacement - Duane S. - 11-20-2012 yeah thats how I did it but I guess I didn't let it run long enough to pull the antifreeze threw thermastat 636 replacement - Duane S. - 11-21-2012 Today I ran the bike set at my idle 4500 with fans on not moving it, let sit there and ran both fans. It took it 10 mins to hit 220 without riding it thermastat 636 replacement - Duane S. - 11-21-2012 Been tryin to get the air out thermastat 636 replacement - navajowalks - 11-21-2012 Are you doing it with the radiator cap on or off? On the side stand (kickstand)? thermastat 636 replacement - navajowalks - 11-21-2012 Have you checked your overflow hoses yet? |
