what could have caused this? - Printable Version
+--- Thread: what could have caused this? (/showthread.php?tid=37341)
Pages: 1 2 3 4 5 6 7 8
what could have caused this? - old man roger - 03-18-2012
Quote Originally Posted by adichino
i so fuckin regret now i didnt take a picture of that tshirt!
tomorrow i will open the engine to see what went wrong .. pretty excited coz it's my first time
omr, what electric valve are you talkin about ?
The 636 is vacuum operated, the f4i is electric.
I think it's called the air switch valve on a 636, it's the plastic valve on top of your valve cover.
Air injection control valve on an F4I
what could have caused this? - chino12 - 03-18-2012
if what you are talking about is the stock part which most people use to do the clean air mod instead of a T tube, then i cut the wire, its no longer attached to the main harness
anyway, i stripped down the engine today, found out that 2-3 disks from the clutch are broken and rod #3 had broken and had grenaded into the engine case as most you guys assumed
i didnt manage to remove the flywheel and clutch as i dont have a rotor puller and a clutch center holder
is there any way to remove those without the tools or i need to buy the tools?
Thats exatly the part I was talking about but I was actually replying to stunna dales question, I think your problem was probably caused by the guy that left the t-shirt in there.
you didn't see any large amounts of oil in any of the cylinders right?
what could have caused this? - chino12 - 03-19-2012
the cylinders were clean
its funny coz i bought this bike in 2009, somewhere in august and i opened the engine last month and saw the tshirt ... the engine has run perfectly during all this time
what a rod cannot break if you revlimit that shit 4-5 minutes?
whats your input on those two tools to remove the flywheel and clutch ?
what could have caused this? - PeRkz - 03-21-2012
See knock on wood, ran fine til you took out the magic shirt. Ya fucked yourself man
what could have caused this? - chino12 - 03-24-2012
Quote Originally Posted by PeRkz
true that hahah
i managed today to remove the clutch with an air pistol and the flywheel with a ghetto puller and a torch, split the cases and took it to the welder .. tomorrow i will see his magic cant wait
what could have caused this? - old man roger - 03-24-2012
You're gonna fix that motor? You could probably buy a used one cheaper
yea i will try if not i will buy another f4i
the germans are crazy when it comes to engine prices ... one f4/f4i is at least 600 eur
i paid like 100 eur for the rods, crankshaft and the engine case, the case is not good but probably i will turn it into a small coffee table
the welding is 100 eur tops, so im good with 200 eur, if everything goes fine of course
so today i got the case from the welder, i hope it will hold
so then i went to the garage, cleaned the case and put in the pistons rods and shaft
and assumed that top dead center is when piston 1 and 4 are at the top of the cylinder - that was to me the only way for the rods to be straight
i tighten the the rods to 25nm as written in book
i then tried to rotate the shaft but i couldnt
could this be because of the new set of rods&pistons which might not be aligned to the cylinder?
or i did some stupid shit ...
