F4i Clutch Arm Mod ... Must Have - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: F4i Clutch Arm Mod ... Must Have (/showthread.php?tid=3533) |
F4i Clutch Arm Mod ... Must Have - DIMA - 04-08-2009 both are just as good it's all up to you!!! i'm lazy so it's bolts hahahah
F4i Clutch Arm Mod ... Must Have - damo - 04-09-2009 ive just bolted mine on too but i got a welder last week so i'll join them up properly now (when i get around to it ). It'd be a pain in the ass if the bolts vibrated off!
F4i Clutch Arm Mod ... Must Have - OnEWhEeLNEAL - 04-15-2009 you got more room on the 636 to do it. same as all the others. cut the arm and weld it longer. ask omr for the exact amount he did on his 636. F4i Clutch Arm Mod ... Must Have - old man - 04-17-2009 half inch F4i Clutch Arm Mod ... Must Have - OnEWhEeLNEAL - 04-17-2009 Word fluffer F4i Clutch Arm Mod ... Must Have - old man - 04-18-2009 mine's about 3/4 and still works fine though. F4i Clutch Arm Mod ... Must Have - OnEWhEeLNEAL - 04-19-2009 yeah well on the kawi you could do that. on the f4i you wouldnt be able to get the arm past the frame if it was that long. I speak from experience lol. I sat there cursing at the bike hoping it would help but not so much. F4i Clutch Arm Mod ... Must Have - beardo - 06-15-2009 + on that... moose ez pull + 3/4 inch extension= pinky pull clutch lever!!! F4i Clutch Arm Mod ... Must Have - RocketBurn11 - 05-12-2011 How did you manage to do it with the engine in the frame? Did you pull the clutch cover and the arm out and then put it all back together?
F4i Clutch Arm Mod ... Must Have - Swanny - 05-12-2011 Quote:
.. i kid .. i kid |
