F4i wnb stunter -build - Printable Version
+--- Thread: F4i wnb stunter -build (/showthread.php?tid=34442)
Pages: 1 2 3 4 5 6 7
F4i wnb stunter -build - khalid - 03-05-2012
Originally Posted by CONGO
Wow, you put a hell of a lot of work into that subframe! Good job, I cant wait to see how this build turns out.
Yea +1
F4i wnb stunter -build - Str8JDM - 03-05-2012
im so doing the same thing you did to your tank to mine, howd u cut the bottom out? dremel?
F4i wnb stunter -build - Petomaani - 03-05-2012
I cut the bottom off with an electric jisaw and a steelblade. Here's a picture of this tool if my translation wasn't accurate:
http://hintaseuranta.fi/tuotekuva.as...?kuvaid=533275
That's quite good solution because it's spark-free.
Just a note, any of you guys who are working first time with gas tanks: you cannot be careful enough! The less there's gas in the tank, the louder it'll expolode! Do not use any sparkling method for cutting if the tank smells even littlebit of gasoline from inside.
F4i wnb stunter -build - BirDMaN420 - 03-06-2012
Sub'd. Awesome job so far man
F4i wnb stunter -build - Petomaani - 03-17-2012
Finally some progress with the crash cage. Still couple tubes short, but the hardest part is done!
F4i wnb stunter -build - Hektik2123 - 03-17-2012
Originally Posted by !!A2K!!
Love the yamadog tail!
That tail is bad ass and i dont even like yamahas
F4i wnb stunter -build - mart211 - 03-22-2012
Cage looks solid as hell!
F4i wnb stunter -build - Petomaani - 03-22-2012
Yeah, and it feels like too! Like I said, I'm still learning and hopefully this cage gives me daring to find my limits
I was littlebit suspicious about my 900rr's cage but I think that's not the issue anymore with my F4i - I'm glad that da Liks gave me a hint of this solid cage design I've totally missed before!
GOT TO take my DSRL with me next time for some proper pics...
F4i wnb stunter -build - M.F. Mall Cop - 03-22-2012
how did you do the front axle sliders? Just drill a small hole through the front wheel end cap?
F4i wnb stunter -build - M.F. Mall Cop - 04-20-2012
Hey just curious the grey subframe undertray. how did you do it and what material is it? Welded underneath the subframe? bolted on? I want to do that sometime. Looks so clean.
