07 R6s - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.the-nags.com/forumdisplay.php?fid=104) +--- Thread: 07 R6s (/showthread.php?tid=47522) |
07 R6s - DrJellyFingers - 05-02-2013 my bitches in the sun ![]()
07 R6s - DrJellyFingers - 05-05-2013 this had to go ![]() idk if u can see the difference in pics but i can def feel it on my firm cheeks :D before ![]() after ![]() end result isnt great because i cant sew so i just pulled, tucked and stapled. better than before and more comfortable
07 R6s - 762SPR - 05-06-2013 Try getting some marine vinyl from a local upholstery shop, it will stretch a LOT better than whatever you have on there now. Sewing is pretty easy if you are just doing basic stuff. Just make your pattern, add half an inch all the way around the sewn seams on both pieces, then line them up, pin them together and sew. I literally learned how to sew from making my first seat cover when doing my hole in seat. just last friday I re-did my front seat because it had holes. ![]() I probably could have done it with one piece but I like the way it looks with the seams so that's what I did. 07 R6s - DrJellyFingers - 06-10-2013 a friend fixing the shitty 4stunt subframe that doesnt fucking fit. ![]() bam ![]() back home reassembling everything ![]() new spark plugs in it and took it for a quick ride, holy shit, i feels completely different and even sounds different. pulls the front wheel up way easier now, shoulda changed the plugs the day i got it (ill try to get some action shots later when someone is around to take pics)
07 R6s - Paul - 06-10-2013 jelly... i dont wanna tell u how to set up ur bike but once u start wheelin'ing it i'd zip tie that brake light under the sub 07 R6s - Patient-zero - 06-11-2013 dude, stretching the leather and staple it under pressure... aint that hard.. the seat doesnt look that nice imo
07 R6s - Atown1101 - 06-15-2013 is that my old double bar cage ? 07 R6s - Duane S. - 06-15-2013 Kinda looks like it 07 R6s - Atown1101 - 06-15-2013 i dont remember having my double bar mounting to the swing arm though ! i switched to the single by that time 07 R6s - DrJellyFingers - 10-03-2013 bike i getting there slowly. got a cheap tank off ebay with a dent on the side so i banged it today ![]() did the clean air mod ![]() 56t sprocket and new chain ![]() got a free headlight from the shop, its off a honda rebel or shadow i think.
