2003 636 Idle Problem - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 2003 636 Idle Problem (/showthread.php?tid=37517) |
2003 636 Idle Problem - !!A2K!! - 03-29-2012 A dyno will show if its running lean/rich. Im sure the dyno and tune will fix the problem. U cant add better airflow to an engine and expect it to run good on oem settings. 2003 636 Idle Problem - ROWDY - 03-29-2012 For reference, mine makes right at 106 whp with slipon pipe and pc3 2003 636 Idle Problem - Twite - 03-30-2012 Swapped it. No difference. I think I may swap engines and use these current sensors, ecu, and harness. This should let me know if it is in fact the head work. 2003 636 Idle Problem - ToKwik - 03-30-2012 I guess that's one way to do it. I know its easy to pop and swap a 636 motor, but 5 min on the dyno I think will tell you more. ![]() Just out of curiosity, have you checked the wires to the sub-throttle assembly? One other place I've found issues is the wiring for the cam sensor getting cooked. I now wrap those in heat tape during reassembly. Hope you get it figured out.
2003 636 Idle Problem - Twite - 03-31-2012 I don't either at this point...but there's nothing else. I have changed EVERYTHING. 2003 636 Idle Problem - !!A2K!! - 03-31-2012 Did you pc3 and dyno yet???? Ive said this 3 times lololol 2003 636 Idle Problem - !!A2K!! - 03-31-2012 Twite, did you get the head decked as well or just port and polish? 2003 636 Idle Problem - ToKwik - 03-31-2012 A PCIII won't fix any run-ability problems. The only other weird thing I have come across that may be related was a bad fuel pump. Bike would run fine, but wouldn't idle worth a damn. Pump ended up only putting out about 20psi when it needed to be double that.
2003 636 Idle Problem - Twite - 03-31-2012 I've tried fuel pump. PCIII didn't make a difference. I tried adding 10% and subtracting 10% fuel in the low rpm range (1000-3500). Didn't get a reaction, positive or negative. I believe I have no officially tried everything. Going to swap in another engine, but use the current harness, ecu, and sensors to see what happens. Sooo excited... 2003 636 Idle Problem - !!A2K!! - 03-31-2012 Was the head decked??? |
