2006 Kawi 636 - Idle Issue - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 2006 Kawi 636 - Idle Issue (/showthread.php?tid=20241) |
2006 Kawi 636 - Idle Issue - jordo636 - 11-06-2010 Hey Guys, I've hit a wall with this new motor and need some help. The idle seems to drop whenever I'm in a circle on idle. NH's are impossible as-is basic NTH's and all other idle tricks. It seems to be getting worse the more I ride on this motor. Here's what I've done and tried so far. - put stock exhaust back on with valve - put after market exhaust on with-out valve. - put on previous throttle bodies - changed spark plugs - changed air filter - used previous tank and pump (didn't have problems before with idle) - checked idle cables and mechanism - changed oil twice - changed clutch plates and friction plates - changed wiring harness - changed CPU None of these changes had any affect on how the bike idled. The motor that I put in had 20k miles on it but was not stunted.
Thanks for your help! |
