03/04 636 4piston radial caliper brackets - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Classifieds (https://stuntride.the-nags.com/forumdisplay.php?fid=6) +--- Forum: For Sale - Parts/Accessories (https://stuntride.the-nags.com/forumdisplay.php?fid=15) +--- Thread: 03/04 636 4piston radial caliper brackets (/showthread.php?tid=18345) |
03/04 636 4piston radial caliper brackets - A.TEK - 09-13-2010 TIP TOP READY TO ROCK! current orders out tomorrow, got a few left. take a real close look at edub's x-games pic. his skill, my bracket and a gxsr 1k caliper. +BENEFITS+ -replaces the oem chain adjustment block. -moves with your wheel and axle when you adjust chain. -HAVING A DEDICATED 4 PISTON RADIAL CALIPER! -cnc'd aluminum block. -can use almost any front radial brake rotor, LEFT or RIGHT side. -easy tire changes. push axle out and slide bracket/caliper off rotor out of swingarm, then axle completely out and wheel off. wheel on: put wheel up and axle through to other side of swingarm, slide bracket/caliper on rotor and into swingarm, push axle through bracket, tighten castle nut and adjust chain tensioner. -all brackets are mounted and tested prior to shipping. -can be fitted to the big rotor!!! will have other models made soon for 05+ ninja, 04+ gsxr as well in the coming weeks. also will be milling big rotor adapters for the oem 03/04 636 calipers |
