r6 setup - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: r6 setup (/showthread.php?tid=9643) |
r6 setup - Beto - 08-13-2026 \r\n \r\n \r\n post some pics, I\'m sure it should fit the same on a stock sub...check your pms too Quote: \r\n
r6 setup - slidewayz89 - 08-13-2026 \r\n \r\n \r\n O it will fit the same just wont look the same it will be a little shorter on the a-town subframe.\r\n
Quote: \r\n
r6 setup - slidewayz89 - 08-13-2026 \r\n \r\n ![]() \n \nthat is with the subframe almost flush with the tail section looks great let me know...\r\n r6 setup - jabreu3 - 08-13-2026 \r\n \r\n got an atown cage and soon to have a subframe to match... wouldnt run anything else... plus my omr gets me chicks so im golden!\r\n r6 setup - DC-stunts - 08-13-2026 \r\n \r\n \r\n \nQuote: \r\n
\n \nBad copy of the C4 bar sorry but you know its a copy. \nThis is the C4 one 3 years before the a town and it fits the same on stock and c4 sub. \n \n r6 setup - !!A2K!! - 08-13-2026 \r\n \r\n \r\n this is true....got my rearsets and upper on....ill be gettin the subcage, bar, and subframe soon...Quote: \r\n
![]() \r\n
r6 setup - SDFKILLZ - 08-13-2026 \r\n \r\n \r\n i highly doubt he got one of your bars and designed it after yours. the bottom line is with alot of stunt parts theres only so many ways to make them. really how different can you make an internal 12 bar? how many diff ways can you make a round bar or flat 12 bar? if you were worried about a copy you shoulda registered for a patent.Quote: \r\n
![]() \n \ni think a competitive market is a good thing. drives the prices down for us consumers and gives us options which is never a bad thing.\r\n r6 setup - DILTS - 08-13-2026 \r\n \r\n \r\n ...Quote: \r\n
\r\n \r\n+1\r\n r6 setup - Tough Luck - 08-13-2026 \r\n \r\n \r\n This is the way to go i have the subframe and its nice i am going to be replacing my powers cage with the atown cage i would get the C4-revolutions subframe just because it uses all stock 12 bars and round bars bolt right up the Atown subframe can only use his mini 12 bar or round bar. Also get a Hohey big rotor kit and FTi F4i pro bars for DB bars best in the world to get a littel pricey but will save you in the long run on replacing db bars they twist instead of break like regular db bars\r\n
Quote: \r\n
r6 setup - mofat01 - 08-13-2026 \r\n \r\n \r\n Quote: \r\n
i think i may jump on the r6 bandwagon since i cant find a 636\r\n
