Rsc levers - Printable Version
+--- Thread: Rsc levers (/showthread.php?tid=46565)
Pages: 1 2 3 4
Rsc levers - Stubbz63 - 01-14-2013
should work fine just dont take to much off so you get the most leverage as possible. i cut mine off my 16mm also just so it wont break if it hits the ground
Rsc levers - Righteous 1 - 01-15-2013
I don't know who's set up this is, but i stole this picture a few months ago when I started getting into stunt riding. I have the same rsc and magura but I haven't got a dcb yet so the magura is sitting in the closet. I like how the lever is cut down so i wouldnt have to worry about bending or breaking it. For those of you who have used 13mm maguras, what kind of HB calliper would you recommend using with the 13mm with a trimmed down lever?? Will it work well with a 4 piston? Or should I just leave the lever full length
That's my old setup.
It was linked to a conventional 4 piston Honda caliper(which I still use today), and worked awesome!! I recommend it.
Rsc levers - StuntBikeJake - 01-15-2013
ASV unbreakable levers FTW!
I have no worries about my levers if they do hit the ground... too bad they dont make one for the maguras..
Rsc levers - Stubbz63 - 01-15-2013
what you runnin for ASV levers? where?
i've never once broken a lever off so not very worried about it but curious. i can get ASV's fairly cheap but dont see the need.
Rsc levers - NBstunter - 01-15-2013
my setup. love it. just not the fact it hasnt been used in 4 months due to it being winter
98 cbr f3 with flipped stockers with 3 inches welded on to them.
oh yeah its a frembo 16/18 [knock the frembo all u want 2 years trouble free] with a 6 piston gsxr caliper works AWESOME
Run them on my brembo master. I'm hunting a 19x18 or 19x20 for my front brakes. I just ordered a shorty lever for my hb cuz the long lever was giving me issues with my gimp hand.
Rsc levers - broham - 01-15-2013
Awesome!! I might end up copying your setup if ya dont mind
