Weight Reduction - Printable Version
+--- Thread: Weight Reduction (/showthread.php?tid=35908)
Pages: 1 2 3 4
Weight Reduction - ReCkLeSsRyAn - 08-13-2026
\r\n \r\n It snowed last night \r\n
Weight Reduction - $Evan$ - 08-13-2026
\r\n \r\n i started by removing my radiator to shave weight comes up a lot faster. but i can figure why my bike keeps overheating so bad\r\n
Weight Reduction - !!A2K!! - 08-13-2026
\r\n Originally Posted by B-rup\r\n View Post\r\n
True, for road racing, but who honestly buys these for stunt riding
\r\nIm just curious, not here to argue.
I did....\r\n
\r\n Originally Posted by lee majors\r\n View Post\r\n
light wheels typically are considered unsprung weight, which only aid in making acceleration quicker. but in a wheelie, the rear is the only wheel on the ground so, in that case, the front wheel would also be sprung weight. if that makes any sense.
Every ounce of weight on a 17 inch wheel equals 25 pounds at 100 mph\r\n
Weight Reduction - J Blox - 08-13-2026
\r\n Originally Posted by jbstunt69\r\n View Post\r\n
Ya keep telling yourself that to justify the $ you\'ve spent buddy , but your a prime example of what I\'m talking about. Just because you go to comps and rub elbows with the pros doesn\'t make you a better rider nor does it mean you need the same quality parts as a top level rider. Until you start placing on the podium you should be more worried about practicing then having the same parts as a top level rider. Cause you don\'t need em yet. Whether or not you want to believe it or not that\'s the truth.
Weight Reduction - loogie - 08-13-2026
\r\n Originally Posted by J Blox\r\n View Post\r\n
Elbow rubber!\r\n
Weight Reduction - R6stuntSC - 01-27-2012
Couldnt be more than 10 lbs. i wouldnt think i made one for my r6 weighed 8lbs
