F4i wnb stunter -build - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.the-nags.com/forumdisplay.php?fid=104) +--- Thread: F4i wnb stunter -build (/showthread.php?tid=34442) |
F4i wnb stunter -build - Petomaani - 08-13-2026 \r\n \r\n \r\n No, I think it pulls more like 636 Quote: \r\n
![]() \nI\'m making this tail conversion because this bike is going to be my daily ride. The stock tail would be my choise for 100% stunt bike.\r\n F4i wnb stunter -build - chino12 - 08-13-2026 \r\n \r\n nice! so now what, do you sell the banana seat?\r\n F4i wnb stunter -build - Petomaani - 08-13-2026 \r\n \r\n \r\n I\'ll keep it for backup.\r\n
Quote: \r\n
F4i wnb stunter -build - Mr.Apple - 08-13-2026 \r\n \r\n Been watching and reading your build and great job. I want to know how you are going to do your cage. what you will use and the design. Im fabbing up my own cage for a 00 zx6r and juts like seeing the stuff others come up with and maybe get better ideas for mine.,\r\n F4i wnb stunter -build - ReckONE - 08-13-2026 \r\n \r\n Damn man you did some work! Looks good.\r\n F4i wnb stunter -build - Petomaani - 08-13-2026 \r\n \r\n Thanks guys! Today I\'m going to garage again and hopefully I\'ll be able to start working with the crash cage (there\'s still some work to do with the subframe). \n \nCrash cage desing will be quite basic, something like Sick Innovation\'s cages. I\'ll measure all the tubes and other material which I\'ll be using with the cage and post it up into this thread. \n \nOT: I finally got sold my 900rr...\r\n F4i wnb stunter -build - Petomaani - 08-13-2026 \r\n \r\n Went to garage yesterday - no pics... But this is the trend of today: project thread without pics, right? ![]() \n \nYesterdays progress: \n \n- made a rear mount for passenger\'s seat \n- bent chrash cage lower tube, which goes under the motor \n- started to fabricate cage\'s front mounts \n \nTubes I\'m using in crash cage are two kind of waterpipes. Thinner pipe\'s diameter is 21mm and wall thickness 3mm, thicker pipe\'s diameter is 30mm and wall thickness 2,5mm. \n \nI\'m using this thicker pipe in cage front mounts, which also connects all other pipes. All other pipes will be that thinner one. \n \nI\'m gonna make another visit to garage in this week, I promise some new pics after that \r\n
F4i wnb stunter -build - !!A2K!! - 08-13-2026 \r\n \r\n Love the yamadog tail!\r\n F4i wnb stunter -build - Petomaani - 12-07-2011 Here's a project topic of my F4i stunt build. I bought this '05 F4i crashed, and how do you say.. redeemd (without titles, because of that crash). It's got 22 000 kilometers on it and it was totally stock in all ways. My plan was to re-register it (for titles) in stock condition and make a stunt bike from it after registartion as cheap as possible. Here's few pics as I bought it: ![]() ![]() ![]() ![]() All plastics were split/damaged in some way and tank was garbage, but it was techincally working fine and all drivable. Story continues... F4i wnb stunter -build - #TMNT - 02-16-2012 how do you have no rep power???? repped sir!! |
