.38 Special - Project Build - Printable Version
+--- Thread: .38 Special - Project Build (/showthread.php?tid=32705)
Pages: 1 2 3 4 5
.38 Special - Project Build - Raider - 10-13-2011
Very nice! This is exactly what I'm doing to mine as soon as I get the extra $$$ for an 07-08 hb bracket!
How straight forward is the 08 swingarm swap? I looked around and saw a lot for 05-06....
Loogie, feel free to chime in
.38 Special - Project Build - StuntBikeJake - 10-13-2011
You will need a 17mm allen to get the bolt out of the 03, use everything from the 08, the shock, the linkage, the dog bones. You will need to remove the right side dust seal out of the 08 swinger and put the right side spacer out of the 03 swinger in and everything will line up like it was meant to fit. Then reinstall the same way it all came out using the 03 swingarm bolt and nuts.
Very cool. Stoked to get it on, just waiting to hear if my hohey will fit.
.38 Special - Project Build - 0410r - 10-13-2011
Quote Originally Posted by StuntBikeJake
Really?
fking at&t blocks everything i can see it now and i can see its going to look great
.38 Special - Project Build - navajowalks - 10-13-2011
Sounds good bud, ill definitely hit ya up if it doesnt work out..
Screw that 08! If I could make it a rolling chassis without wasting good parts I would ghost ride it off a cliff....
screw that scrap the metal! lol
Quote Originally Posted by Paul_G
You'll love the 636!!
I switched from an 07 ZX6R to an 04 636 last year and I haven't touched my 07 since.
+1 i think i helped influence jake into this build...
my 07 is gone now!
.38 Special - Project Build - navajowalks - 10-14-2011
did it not come with a 03 upper triple use that one? screw the 07 triples lol
.38 Special - Project Build - StuntBikeJake - 10-14-2011
Came with an 05-08 triple on it... cut down the 08 one, and now we are golden...
Running into a couple issues with trying to run the 08 radiator.. gotta do some investigating and see whats up, may not be able to run it after all...
.38 Special - Project Build - beardo - 10-14-2011
Quote Originally Posted by mdub4life29
Subscribed
me four
.38 Special - Project Build - loogie - 10-14-2011
What issues? FF clearance issues?
Havent even got to that step yet.... more like there is an extra outlet on the 03 radiator that isnt on the 08....
