F4i 2nd Idle Mod Install and Clean Air Mod Pics - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: F4i 2nd Idle Mod Install and Clean Air Mod Pics (/showthread.php?tid=25600) |
F4i 2nd Idle Mod Install and Clean Air Mod Pics - Joe Slow - 04-09-2011 Awesome write.up man! Already did kleen air on my bike but wish this sticky was here back then! Would have saved me numerous searches here and on SL. Then on the debate of the stock idle adjuster. I took out my throttles the other day for a cleanout as they where a bit dirty. I checked where the stock idle cable pushes and its on a plate that is directly connected and part of the choke system. I pushed it all the way in with my finger and checked the butterflys for any movement! I swear they did not even move a thou of a millimeter! I'm sure someone like OMR or the other big names can agree on this perhaps? Just wanted to throw in my feelings. Just to clarify it was also on a 01 F4i. Still need to do 2nd idle mod but can't get round to it. I'm gonna use a speedometer cable and get a screw attached to that. Its a tad longer than the 900 idle cable and very direct but will see how it turns out! Again great writeup! F4i 2nd Idle Mod Install and Clean Air Mod Pics - CHILI - 04-13-2011 Great writeup. ![]() Pics and easy explanation really makes everything about the mods make more sense to me. Ill be doing both mods this weekend!! F4i 2nd Idle Mod Install and Clean Air Mod Pics - *Gswitch33 - 04-13-2011 Pretty much the most detailed write up ever! Thanks for the help.
F4i 2nd Idle Mod Install and Clean Air Mod Pics - Chambo - 04-14-2011 Great write up! Got my 2nd idle cable on the way and clean air mod is going to be done this weekend!
F4i 2nd Idle Mod Install and Clean Air Mod Pics - Sproutn - 04-14-2011 Should you set the stock(wax) idle cable to 1300 befor you remove the throttle stopper? Or do you just back the 2nd idle cable out untill the stock idle catches then adjus? F4i 2nd Idle Mod Install and Clean Air Mod Pics - M.F. Mall Cop - 04-14-2011 Back the 2nd idle cable out untill you hear no change. Then adjust your stock to around 1300. Never touch the stock again, just adjust from the 2nd cable from then on. F4i 2nd Idle Mod Install and Clean Air Mod Pics - Sproutn - 04-16-2011 Thanks man! My stock idle was way low, bike feels happier now. F4i 2nd Idle Mod Install and Clean Air Mod Pics - tipper13 - 04-26-2011 quetion, what u guys do with the valve? leave it bolted up and plugged in, or unplugg it and take it off? dont kno if it will set a code if unplugged F4i 2nd Idle Mod Install and Clean Air Mod Pics - M.F. Mall Cop - 04-26-2011 Mines out. Dont need it and hasnt set off any codes for me. F4i 2nd Idle Mod Install and Clean Air Mod Pics - Sunner - 05-08-2011 Can someone help me out here, Im trying to find an 'idle cable' so I can do the sencond idle mod but I am having no luck, Im searching 'Honda Idle cable' or 'Idle cable'. No luck, what should I be looking for or anyone know where I can get one. |
