2006 Kawi 636 - Idle Issue - Printable Version
+--- Thread: 2006 Kawi 636 - Idle Issue (/showthread.php?tid=20241)
Pages: 1 2 3 4 5
2006 Kawi 636 - Idle Issue - jordo636 - 08-13-2026
\r\n \r\n It didn\'t seem to have any jitters was pretty easy to tune.
\nWhen you used them did you tune at two different idle settings? I just tuned at the low idle setting.\r\n
2006 Kawi 636 - Idle Issue - CoRey - 08-13-2026
\r\n Originally Posted by jordo636\r\n View Post\r\n
First pic is the old MSR and the second is the RSC. You can see how ghetto rigged I had the MSR.
that same zip ties around mine, thnx to petro\r\n
2006 Kawi 636 - Idle Issue - BIGJBEARS - 08-13-2026
\r\n Originally Posted by Naarden\r\n View Post\r\n
The fluid in the motion pro was it real jittery? Ive heard the motion pros kinda suck compared to the ones from england.
\nBasically ever since the took mercury out of them.
they give you restrictors that really help with the fuel injected bikes. and you have to zero out the guage every time you use it. But as long as you do that stuff its a great guage for under $100\r\n
2006 Kawi 636 - Idle Issue - loogie - 08-13-2026
I\'m throwing down a nasty session in front of my house after work! Gonna see if this shit is fixed.
2006 Kawi 636 - Idle Issue - ALEXD - 08-13-2026
\r\n \r\n My bike had a similar issue where the idle would drop real low from time to time and it ended up being my map sensor I don\'t know if this could be it but it\'s a thought\r\n
2006 Kawi 636 - Idle Issue - erkeene - 08-13-2026
\r\n \r\n So it was the vacuum line right? How did it.help when u synced them??\r\n
\r\n \r\n I threw done a nasty sesh out front but my problem still exists, LOL...
\nThe bike is running smoother though and it doesn\'t seem to bog at all now. The idle still drops really low when going slow. It\'s pretty crazy, I have to turn the idle way up and hit no handers fast so that it stays on idle. If I try to hit them slow i just either mouse trap or I have to keep grabbing the gas to bump it back.
\nI honestly think the valves need to be shimmed. I\'ll check the map sensor though that\'s not a bad idea.\r\n
\r\n \r\n bump... what do you guys think? I\'m gonna let toler ride it this week and see what he thinks\r\n
2006 Kawi 636 - Idle Issue - iRiEsTuNtAh! - 08-13-2026
\r\n \r\n \r\n
2006 Kawi 636 - Idle Issue - Duane S. - 08-13-2026
\nwell ryan from austin is coming so he might beable to help \r\n
