04 636 Build... - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.the-nags.com/forumdisplay.php?fid=104) +--- Thread: 04 636 Build... (/showthread.php?tid=12452) |
04 636 Build... - T-Dubby - 08-12-2026 \r\n \r\n \r\n What did you have to change? Also did you use the 04 rear axle? Yeah I\'m putting on the 07 with 07 08 rear shock\r\n
Quote: \r\n
04 636 Build... - MVSBrendon - 08-12-2026 \r\n \r\n \r\n I used the complete 06 rear end with wheel and spacers.\r\n
Quote: \r\n
04 636 Build... - T-Dubby - 08-12-2026 \r\n \r\n \r\n So used the axle then? lol. Yeah I got a a complete 07 08. swingarm, shock, spacers and rim and now and axle cause I wasn\'t sure the stock 04 would work. What did you changed on the shock mounting?\r\n
Quote: \r\n
04 636 Build... - ADBZ Matt - 08-12-2026 \r\n \r\n Wow Bro! Nice build! keep the story updated and pics coming.... May be a good SR article!\r\n 04 636 Build... - MVSBrendon - 08-12-2026 \r\n \r\n \r\n ok, the list is as follows.Quote: \r\n
\n \n04 swing arm pivot bolt and spacer. \n06 swing arm, but I had to mod the chain guard a little, you\'ll notice when you go to put it on, it rubs a little and you have to just cut a hair off to get the pivot bolt to line up. \n06 shock, linkage but you have to take the top shackle off of the 04 shock and use that. It through bolts at the top of the shock and has a nut with cotter pin to the frame. The 06 one is off set and won\'t fit with the 04 frame. \n06 rim complete with spacer and all brackets (less the brake which was fab\'s, but measurements taken off of the stock bracket). \nDepending on your exhaust, you might have to space it out, my high mount hit the 06 swing arm. This isn\'t a big deal because I am fab\'ing up an undertail exhaust soon. You can not use 06 headers wither, the header tube for the #1 cylinder hits the oil filter. \n \n \r\n Thanks man, been building a lot of my own items for a while with race cars and bikes. Thinking about designing a line of products. Quote: \r\n
\n \n \nTodays shakedown was good. I can say that the 4 piston FB is a bit overkill, but once you get used to it, it is money. The HB is nice and firm too. I am better with FB, so I am not a good judge for the HB as of yet. Also, ran both FB and HB HARD for a good session and they did over heat, BUT by having them both bolted to a full billet aluminum bracket the heat sinked out real quick (5min) and you were able to ride again without a bleed. \n \nI\'ll post up some more pics soon. My body work is out to paint and my bike looks like shit.\r\n 04 636 Build... - T-Dubby - 08-12-2026 \r\n \r\n Thank you sooo much for the info man. I really appreciate it\r\n 04 636 Build... - MVSBrendon - 08-12-2026 \r\n \r\n \r\n No worries, if you have any more questions, let me know. It\'s a pretty straight forward swap though. Next time I\'m in Phoenix we\'ll grab a few Quote: \r\n
04 636 Build... - T-Dubby - 08-12-2026 \r\n \r\n \r\n Yeah buddyQuote: \r\n
04 636 Build... - 12oclockroc - 08-12-2026 \r\n \r\n \r\n can i get one of these please Quote: \r\n
but yea where can i get one\r\n
04 636 Build... - MVSBrendon - 03-13-2010 I finally got all my parts that I needed and some time at a friends machine shop, here's some of the pics I got today. ![]() 06 wheels, swing arm and shock... ![]() Mock up. ![]() Andy doin' his thing... ![]() ![]() ![]() ![]() ![]() Cutting side 1 ![]() Cutting side 2. That's all I got for right now, going out to the shop to do some fit up, more coming soon.....
