2014 Street Triple Build!!! - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.the-nags.com/forumdisplay.php?fid=104) +--- Thread: 2014 Street Triple Build!!! (/showthread.php?tid=53402) |
2014 Street Triple Build!!! - sambo - 02-01-2015 Where are you getting your cage from ?> 2014 Street Triple Build!!! - Mr Weber - 02-01-2015 Chris @ fuel forged is building me a cage and sub cage 2014 Street Triple Build!!! - Mr Weber - 02-02-2015 Caliper bracket and calipers line up great, should work nicely! The handbrake caliper in this picture in not the right one, but you get the idea!!
2014 Street Triple Build!!! - JBoom - 02-02-2015 Like a glove!!! Nice work man. 2014 Street Triple Build!!! - Mr Weber - 02-02-2015 Thanks buddy! I hope to have more done by the end of the week 2014 Street Triple Build!!! - Mr Weber - 02-09-2015 UPDATE!! Completely removed ABS system! and rear pegs ![]() Relocated the gage cluster! also installed Idle cable and removed stepper motor, but you can not see it in this picture ![]() The way it sits now. Should see the cage, subcage, and seat this week! Next, need to measure and order all brake lines and master cylinders! Tank is a week or 2 out yet
2014 Street Triple Build!!! - broham - 02-09-2015 take a hammer to the tank already! 2014 Street Triple Build!!! - Stubbz63 - 02-09-2015 lookin good 2014 Street Triple Build!!! - Mr Weber - 02-09-2015 I already did! The tank on it there is the minty one, the dented tank is out at paint! I put this one back on so i could test and make sure eveything was still working correctly after removing all the abs and stepper motor! Here is a pic before it went out to paint, Thanks!
2014 Street Triple Build!!! - broham - 02-09-2015 looks pretty good. Was it tough to dent? and about how much bondo build up do you have on that lip? |
