Stubbz 05 R6 Build - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.the-nags.com/forumdisplay.php?fid=104) +--- Thread: Stubbz 05 R6 Build (/showthread.php?tid=45802) |
Stubbz 05 R6 Build - Stubbz63 - 12-17-2012 last night im puttin the side covers back on the engine, i get to the last cover get all bolts in loosely tightened, criss cross pattern with the torque wrench get to the very last bolt and the fucker strips before the torque wrench clicks, FML! hopefully i can fit a bolt about 1/4" longer in there and snug it up good, its just the rotor cover so should be ok but deff not what i wanted to happen. my torque wrench is brand new and i even bought one for inch lbs for doing lower ft. lb. torques. i find that bigger torque wrenches dont like to click on very low torques so figured the inch lbs. set at 1.5 would be good cuz its only like 8.7ft lbs. worked great for the other 20 bolts lol Stubbz 05 R6 Build - Stubbz63 - 12-17-2012 pic of the rims. ![]() frame comin together ![]() front rim with rotors on, lil diff shade of white but idc didnt expect it to be perfect bein that ones powder and ones real paint. pic makes it look worse i think.
Stubbz 05 R6 Build - SQUINTS - 12-17-2012 damn that thing is gonna be pretty Stubbz 05 R6 Build - RUTHLESS RAH - 12-17-2012 i powder coated my rotors for the kawi, and they fuckin bent.....never again Stubbz 05 R6 Build - Stubbz63 - 12-17-2012 what ya mean they bent, just from riding or from powdering them Stubbz 05 R6 Build - GIL with 1 L - 12-17-2012 Your powdercoater probably did you dirty Stubbz 05 R6 Build - RUTHLESS RAH - 12-17-2012 yea they had a bad wobble or dirty mike did me dirty!!! i cant say 100% who did me dirty Stubbz 05 R6 Build - Stubbz63 - 12-17-2012 were the rims powdercoated as well? if the rims werent tapped off where the rotors sit on them ya coulda had powder causing them to sit differently. Stubbz 05 R6 Build - GIL with 1 L - 12-17-2012 Powdercoating doesn't damage rotors Stubbz 05 R6 Build - COOLIE - 12-17-2012 The blue looks legit ! |
