03-05 r6 common problems - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 03-05 r6 common problems (/showthread.php?tid=16469) |
03-05 r6 common problems - reds919hornet - 07-23-2010 i have after a good pancake. took me a minute to figure out why the bike would not start afterwards. just pulled the pump and snapped it back together again and have not had any problems since. but i have not pancaked it since either.
03-05 r6 common problems - Ridick_Bowen - 07-23-2010 I've had no problem yet. The subframe is garbage though. Other than that everything is cool. 03-05 r6 common problems - Ridick_Bowen - 07-23-2010 finding stunt parts is pretty limited. Sucks!! 03-05 r6 common problems - BLEED - 07-24-2010 what parts are you needing??? 03-05 r6 common problems - Ridick_Bowen - 07-26-2010 subframe hohey dual caliper bracket with lines and mc sprocket and chain 03-05 r6 common problems - BLEED - 07-26-2010 atown has dope subframes. its probably best to buy new chain and sprockets cause you dont know how hard and long that chain/sprocket was beat to shit. 03-05 r6 common problems - Ridick_Bowen - 07-27-2010 Should have started on a F4I . Oh well, I'll just rock the R6 till I break it.
03-05 r6 common problems - Beto - 07-27-2010 I think my fuel pump came apart in the tank, other than that I got no complaints 03-05 r6 common problems - BLEED - 07-28-2010 yea i started on a 05 r6 then switched to a f4i. love learning the tricks on the f4i then i'm going to jump on my 03 r6 in due time lol. 03-05 r6 common problems - BLEED - 07-28-2010 do you need a subframe cage? i have a sick that i'm not using going to omr. pretty good condition. let me know pm me your number and i'll shoot you pics. |
