how much psi to run for 0's - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: how much psi to run for 0's (/showthread.php?tid=9411) Pages:
how much psi to run for 0's - 12oclocker - 12-23-2009 stock pressure works good. how much psi to run for 0's - T-Dubby - 12-23-2009 Quote:
how much psi to run for 0's - BIGBEN954 - 12-23-2009 +1 anything less than 36 makes em hard to turn, fells like its on the side of the rim. Just set it high and get used to it. If you try to bump it up every couple times you ride youll be fighting getting used to it every time. 40 will feel weird as shit at first exspecially if your still at that fighting to turn stage but itll be all worth its while in the long run! how much psi to run for 0's - SDFKILLZ - 12-23-2009 Quote:
how much psi to run for 0's - SBS Pez - 12-23-2009 40psi!! Sh1t ive been at 22-25 for about 6 months better get pumping
how much psi to run for 0's - old man roger - 12-24-2009 Quote:
how much psi to run for 0's - krazykyle85 - 12-24-2009 Quote:
he didnt worry about it.but he said normaly he prefers 2 bar which i think is 25 psi?! 37+ PSI rear here
how much psi to run for 0's - armenian. - 12-24-2009 i run 5 psi wassup how much psi to run for 0's - big ben - 12-24-2009 i got a new tire with a lot of curve on it..... i had to lower the psi to 35 but found if you dip it in in flamingo u can use yor leg to help shift your weight.... i worked for an hour trying to not low side in SS but kicked that leg out helped getting used to it really fast. how much psi to run for 0's - BIGBEN954 - 12-24-2009 Quote:
