Thread not archived - Stuntride - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Pictures (https://stuntride.the-nags.com/forumdisplay.php?fid=32) +--- Thread: Thread not archived - Stuntride (/showthread.php?tid=7574) |
Thread not archived - Stuntride - Stubbz63 - 09-09-2013 Not sure what it would rub but i know it can still be riden fine like that. Track down Hawaiian Eddie and ask him where his was rubbing im not sure if he had a rad cage on his but i would assume so. Not sure on radius either would probly have to compare both lower triples to compare the stops on each Thread not archived - Stuntride - Ridick_Bowen - 09-09-2013 Mine rubs my DCP radiator cage. I have to lift the bike an 0.5-1" for clearance. Thread not archived - Stuntride - reds919hornet - 09-10-2013 a-town or a2k done a write up about making all kinds of adjustments through your cluster a few years ago. I will see if I can find it. Thread not archived - Stuntride - reds919hornet - 09-10-2013 here is the thread that a2k started on sl which has a link to a thread on the r6 forum that talks about using your cluster to make adjustments just like a power commander would. http://www.stuntlife.com/forums/2-st...ners-look.html. hope this helps. Thread not archived - Stuntride - GORBO - 09-11-2013 ^^^yep this is it, this is where I orginally got the idea from. and the TPS you just need to make sure your adjusted within specs, it doesnt have anything to do with the exhaust set up Thread not archived - Stuntride - jesterchino - 09-13-2013 Hmm... Interesting... Good info! Thread not archived - Stuntride - reds919hornet - 09-13-2013 gorbo; how did you adjust yours and did it really seem to help? I read through 20 pages on the r6 forum and most were saying that adjusts c02 and c03 made the most difference and seemed to help the most but they are mostly canyon carvers. what did you find that really helps stunters? Thread not archived - Stuntride - kirny - 09-13-2013 Omg more pics homos. Yea that's right I'm still on here lol Thread not archived - Stuntride - Ridick_Bowen - 09-13-2013 You trolling now Kirny? Or do you just miss all this homo action? Thread not archived - Stuntride - vegasrider2005 - 09-13-2013 ![]() ![]()
