all out f4i rebiuld 2.0 - Printable Version
+--- Thread: all out f4i rebiuld 2.0 (/showthread.php?tid=51645)
all out f4i rebiuld 2.0 - -william- - 12-02-2013
so that's how it was without all the bracing
and that's how it is now without the upper subframe mount
and with them
i might add a gusset in the back, i don't know
and i'm thinking about reenforcing all the back of the motormount and the swingarm pivot with a 1/8th of an inch thick plate like this, just with a better fit to the frame. at the same time i could use the as an ancor for my rearsets.
all out f4i rebiuld 2.0 - drewf4i - 12-02-2013
Looks good
Sent from my iPhone using Tapatalk
all out f4i rebiuld 2.0 - sambo - 12-03-2013
Frame looks badass u got skills man
all out f4i rebiuld 2.0 - jesterchino - 12-03-2013
Sweet! Sub'd...
all out f4i rebiuld 2.0 - jc_hernandez_wtsn - 12-04-2013
Nice frame, good job
all out f4i rebiuld 2.0 - DrJellyFingers - 12-04-2013
frame looks great. u building ur own subframe too?
all out f4i rebiuld 2.0 - -william- - 12-04-2013
I'm just gona modify the subframe i built last year, it did great and i don't see why i should change it. I'm only gonna modify it so the pegs on it are going to be a little higher and i want to fit a real backseat on it with a roundbar under it
all out f4i rebiuld 2.0 - jesterchino - 12-04-2013
Wanna make a frame for me??? If so, how much? If not, it was worth a try! Lol
I don't know about that yett... I need to finish it, test it, then i'll know. I dont even know how much its worth. How much would you be ready to pay for something like this ?
all out f4i rebiuld 2.0 - Atown1101 - 12-05-2013
that is a gorgeous frame you should defiantly start slangin those
