how to guide :2005-2008 zx6r fork seal replacement (with pictures) - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: how to guide :2005-2008 zx6r fork seal replacement (with pictures) (/showthread.php?tid=51286) |
how to guide :2005-2008 zx6r fork seal replacement (with pictures) - burnoutnut - 10-11-2013 I gave every thing a good clean including changing all the seals o rings and bushings thats why I did it this way how to guide :2005-2008 zx6r fork seal replacement (with pictures) - navajowalks - 10-11-2013 There is no way to clean those bushings... The coating comes off the inside of one of them when you pull the forks apart... And invest in a seal driver they are like $40 and work on all the Kawis 03-08 how to guide :2005-2008 zx6r fork seal replacement (with pictures) - vegasrider2005 - 10-11-2013 43mm motion pro driver just a FYI, i bought the 50MM and way to big how to guide :2005-2008 zx6r fork seal replacement (with pictures) - navajowalks - 10-11-2013 Yep its the size of the inner tube you need... I did the same thing LOL how to guide :2005-2008 zx6r fork seal replacement (with pictures) - burnoutnut - 10-12-2013 I changed the bushings not clean em.... I gave everything a good clean how to guide :2005-2008 zx6r fork seal replacement (with pictures) - navajowalks - 10-12-2013 I was just saying for anybody else reading... I tried once seals lasted half as long.. how to guide :2005-2008 zx6r fork seal replacement (with pictures) - GAMstunts - 10-14-2013 Can any of you guys tell me which adjusters are for the compression, rebound, and preload on the 07/08zx6r forks? Ive been trying to adjust my forks and am not sure which knob/screw does what. I thought the top small screw was compression, the 19mm adjuster on top was the preload, and the small screw on the bottom of the fork was rebound, but I hate guessing and cant find it on the web without having to download a bunch of stuff. Sorry for thread jacking, I figured if your doing a tutorial you would know the answer. how to guide :2005-2008 zx6r fork seal replacement (with pictures) - navajowalks - 10-14-2013 I belive you have it correct... I know the big part on top is preload... If I remember to check ill double check my Manuel when I get home... how to guide :2005-2008 zx6r fork seal replacement (with pictures) - GAMstunts - 10-14-2013 I'm def confused, I was on another kawi forum and they had the rebound on top and the compression on bottom. Id appreciate any help. how to guide :2005-2008 zx6r fork seal replacement (with pictures) - S.O.R Boomer - 12-24-2013 Compression and pre load is always on the top. Rebounds is on the bottom. ... Sent from my SM-N900P using Tapatalk |
