Full Steel Frame vs Half Steel Frame - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: Full Steel Frame vs Half Steel Frame (/showthread.php?tid=47783) Pages:
Full Steel Frame vs Half Steel Frame - Buddy Luv - 03-06-2013 i think his full ones does weigh a few ounces less than stock. im like the second frame he did so mine is a tad heavier but maybe 2 lbs at most? i feel the weight is more distributed with my full frame if the mounting is the same to the earlier models of r6 you should be able to get you a cage. billie of course or your local welder could mock up something. Full Steel Frame vs Half Steel Frame - StuntBikeJake - 03-06-2013 I just found a crack in my frame... :
Full Steel Frame vs Half Steel Frame - MiNi GuineA - 03-06-2013 I'm on my third frame in 2 years and my badass full frame is the best one so far, if your building a 636 the subframe tabs are prone to cracking especially if you like to do scrapes and such. Nate hit it here the weight is all in the rear. I won't ever forget xdl nashville when my back half broke, horrible feeling Full Steel Frame vs Half Steel Frame - Pirate_jim - 03-08-2013 WHat are the cost diffrence between the two? Full Steel Frame vs Half Steel Frame - Kemosabe - 03-09-2013 Would my bike be ok for stunting on the streets or is it just going to be shit all around? Full Steel Frame vs Half Steel Frame - Kemosabe - 03-09-2013 Full frame - $1530.00 Half frame- $830.00 Full Steel Frame vs Half Steel Frame - kirny - 03-09-2013 He is going off of hear say like most people here the hear one person say something next thing u know its written in the bible do what u want man Full Steel Frame vs Half Steel Frame - Kemosabe - 03-09-2013 Normally I wouldn't take it to heart but I've heard they are all top end. And the r6s has all your low end. But screw it. I'll wheelie on anything I can. Full Steel Frame vs Half Steel Frame - SIC Nate - 03-09-2013 Just an FYI - Billie says he can build a half frame in about 8hrs, where a full frame takes him about 40hrs to build. Full Steel Frame vs Half Steel Frame - Stubbz63 - 03-10-2013 truth but correct also, or spend a bunch of money settin it up let it hold you back for however long while being destroyed then sell it for nothin and go back to a normal bike that works for stuntin like many others already have. been there done that. any bike is fine for street stuntin and can be made to work fine for you tho, there actually a nice bike for street and street stuntin ive riden a few. they are all power on top tho but that doesnt matter as much for streets, have a high balance point i guess but didnt feel to much different for the ones ive stood up but never rode one all set up |
