06 636 bog and wont start!!!! - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 06 636 bog and wont start!!!! (/showthread.php?tid=47124) Pages:
06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-06-2013 ya shockey i know my fuel filter needs cleaned bad, i plan on doin that to while the bikes down!!! 06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-06-2013 another thing i had goin on that i forgot to mention is that my stator wasnt charging the battery, if i bypassed the yellow and black ground wire and ran it straight to the battery ground it worked like a champ, i think i may just need to get a wiring harness but really dont know what would cause all the grounds to melt down like they did ??? 06 636 bog and wont start!!!! - DoWheelies - 02-06-2013 did u think to change the plugs? lol just checkin... 06 636 bog and wont start!!!! - DD_636 - 02-06-2013 that is what i was going to say. sounds like it needs a good tune up. i change my plugs 2-3 times a year as cheap as they are its worth it in my opinion. 06 636 bog and wont start!!!! - RYAN SMITH - 02-06-2013 open circuit to ground. got a meter? 06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-06-2013 Changed the plugs twice, cleaned the air filter and everything 06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-06-2013 Ya i checked the ground and its bouncing all over the place, i bought a main harness today, what im afraid of is hookin the new one up and this happening again, i was told it could be my rectifier but idk how to check that 06 636 bog and wont start!!!! - RYAN SMITH - 02-07-2013 checking the reg is easy, but doesnt sound like a charging problem. ohm out each leg, shouldnt have a reading with the leads reversed. check there is no short to ground from the stator as well 06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-07-2013 ya, im wondering if since the grounds were all melted that was causing my charging issue! i bought a new harness yesterday so that should be arriving saturday or monday at the latest 06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-11-2013 just so everyone know i changed out the wiring harness and it worked like a champ!!! thanks to everyone for the help!!! |
