Suspention set ups - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: Suspention set ups (/showthread.php?tid=46886) |
Suspention set ups - B-rup - 01-27-2013 See I dont like that sinking feeling when you brake hard either, but I like the bounce for certain other things......ugh, the decisions Suspention set ups - osscody - 01-28-2013 Yea, i have lifted my tail section when i did rr tail conversion so saggy ass fix isnt needed to clear a subcage or anything, i was talking about the sponginess like B rup said its like a sinking feeling Suspention set ups - Raider - 01-28-2013 You can go ghetto and wrap the spring with a tire tube like people do when the shock blows out OR you can redrill your shock linkage so that the mechanical advantage to your shock is lowered. Helps stiffen it up a pretty reasonable amount for freeeeeee. I've done it to like 3 f4i's and it works great Suspention set ups - osscody - 01-29-2013 Damn, thats sounds like a winner! I was just thinking that people must b doing something to stiffen em up, any chance u can post up a pic? Suspention set ups - broham - 01-29-2013 some people can't get it hard Suspention set ups - Swanny - 01-29-2013 Front forks: all the way in untill they bottom out on the top and bottom adjustments, then backed them all out 3 clicks. That gives a very consistant feel in the rebound and compression. I HATE fast compression on my stoppies., A nice solid and even up and down IMO feels best. Rear Shocks:as tight as they go till they blow, the tighter the rear susention the more throttle and brake input the rider will notice. Nardeen links change the way the stock rear shock operates on an f4i, so you can actually run a little softer setting to get a smoother but still very responsive feel Suspention set ups - broham - 01-29-2013 what about for bunny hops? Suspention set ups - Stubbz63 - 01-29-2013 you dont want to set your suspension up for bunnyhops, more rebound in the rear would help that but i wouldnt do anything to make bunny hops better cuz everything else will sacrifice for it, not worth it IMO for a corny little 2 inch bunnyhop. add tons of rebound and i bet you could get um pretty high i just wouldnt leave your settings that way Suspention set ups - vegasrider2005 - 01-29-2013 with my rear suspention at the factory setting i can hop over a 2L soda bottle sitting upright, i could also do the bunny hop cluch up things Bill D does, but not with it harder Suspention set ups - Stubbz63 - 01-29-2013 need a pic of that cuz thatd be sick to see it clearin a soda bottle |
