Vic's 03/04 half steel frame RE-build - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.the-nags.com/forumdisplay.php?fid=104) +--- Thread: Vic's 03/04 half steel frame RE-build (/showthread.php?tid=46613) |
Vic's 03/04 half steel frame RE-build - VicOnOne - 01-17-2013 Nope is the 03/04, right frame for the bike just no full fairing tabs or stunt stay mount Vic's 03/04 half steel frame RE-build - kweb636 - 01-17-2013 steel frame and 03/04 forks? build looking good though Vic's 03/04 half steel frame RE-build - VicOnOne - 01-17-2013 I just had the seals replace cause I couldn't find a good price on 05/06 forks and I dont want that money to go to waste Vic's 03/04 half steel frame RE-build - VicOnOne - 01-18-2013 So i went to hollywood B's house to pick up some parts that came in for me, very excited. Stealth Stay!! ![]() So this is the caliper I'm running right now for my ndc bracket, i like it cause its black. ![]() but is has shorter than the stock 636 one and you have to use even more spacers, so I'm selling this one to my boy who is getting the same bracket, and i got... ![]() fits right with only the spacers needed for the big rotor, I'm getting caliper paint for all 4 of my calipers to black em all out and finally a shirt i found in one of hollywood's box of goodies... ![]() hope y'all are liking the thread, i try and put up a lot of pictures cause thats the point right?.. Vic's 03/04 half steel frame RE-build - VicOnOne - 01-19-2013 So i just got a few things started, using high temp black gloss paint on the engine covers and fork bottoms let me little brother "help" me out a bit (help=stand around, look cool and change the song on the stereo haha) ![]() ![]()
Vic's 03/04 half steel frame RE-build - VicOnOne - 01-21-2013 So i Drove 3 hours way to pick up some parts and got some unexpected stuff while i was there Brand new rim with a rotor and decent tire on it for a good price ![]() i got a stock header that is in perfect condition, the one i took off my bike was trashed ![]() i got a muzzy exhaust with the mid pipe ![]() the back is ding up pretty bad in one spot, but I'm going to chop it anyway so ill just chop the back half and ill be good ![]() finished painting the cases and put them on, also had to fix the oil leak on the oil pan ![]() ![]() ![]() and now I'm just waiting on the frame to send everything of to power coating
Vic's 03/04 half steel frame RE-build - VicOnOne - 02-01-2013 So my frame came in and i sent it off to powder coating yesterday! also got my rotor for my NDC bracket. ![]() ![]() ![]()
Vic's 03/04 half steel frame RE-build - Duane S. - 02-01-2013 what did you use to paint the cases? Should be a high temp paint right? Vic's 03/04 half steel frame RE-build - VicOnOne - 02-01-2013 Yep i used a high temp high gloss black spray paint, i think the highest temp was 850 degrees or something. it is normally for bbq's Vic's 03/04 half steel frame RE-build - kruss - 02-02-2013 Lookin good bro. That sucks that dude screwed up on your frames that causes a good month extra wait time. Hopefully hes hooking you up with something. |
