Transmission Issue - Printable Version
+--- Thread: Transmission Issue (/showthread.php?tid=43488)
Transmission Issue - navajowalks - 09-20-2012
So mine pops out of 3rd gear only... Same problem?? Oh and 03 636
Transmission Issue - kirny - 09-20-2012
Haha yes u are right but I have shown them to people before and there like hmmmm I don't see the issue we clearly do
Transmission Issue - JohnnyP - 09-21-2012
yup and those are the people that should not attempt to fix it themselves
Transmission Issue - kirny - 09-21-2012
Haha true I think I still have my shift forks ill put up pics if I do they were so fucked
Here is the one fork from that rebuild, not too bad but still needed to be replaced...
Transmission Issue - 802bouffard - 09-21-2012
I just rebuilt mine last night!!!!
If you get full new trans make sure you can either reuse the shaft that goes to your clutch basket or get it for your bike 05 has less threads than the 06 and you can't bolt the basket on just my
^^^^^im gonna have to do some research case that sounds very false to me
That is not correct, the 2005 and 2006 ZX6R use the exact same Input shaft...Part number 13127-0021 for both...
The 03/04 shares some of the gears, but that shaft will not fit as it does not have a slipper clutch like the 05/06...Also the 2005 and 2006 ZX6RR have a different part number, so that may also not fit a 636
I knew you would come through on thi lol
