Advice on cages f4i - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: Advice on cages f4i (/showthread.php?tid=41009) Pages:
Advice on cages f4i - matthunter1448 - 06-27-2012 ^^^ what he said. Atown for ftw Advice on cages f4i - Str8JDM - 06-27-2012 atown over sick innovations. same cage, just think the rear mounting point on the atown is better to the subframe... i heard the 905 getting good reviews. it used to be a garbage cage but after the redesign a lot of people are talking good Advice on cages f4i - M.F. Mall Cop - 06-28-2012 Atown ftw! Advice on cages f4i - MickeyStunt - 06-28-2012 Quote:
Advice on cages f4i - Swanny - 06-28-2012 Quote:
... .... did you seriously just recommend a 905cage.??
Advice on cages f4i - MiNi GuineA - 07-04-2012 Quote:
Advice on cages f4i - Str8JDM - 07-05-2012 sick and atown are the same cages. sick mounts to the rear mount, atown mounts to lower subframe bolt. ive busted rear mounts wit the sick cage, therefore i like the atowns mount to the subframe bolt better Advice on cages f4i - MiNi GuineA - 07-05-2012 Quote:
![]() Neither of thoes cages have anything to do with the lower subframe bolt they do both mount to the swing arm pivot?
Advice on cages f4i - Ethiopian - 07-05-2012 Quote:
Advice on cages f4i - Str8JDM - 07-05-2012 Quote:
the atown mounts to the lower subframe bolt on the f4i ![]() sick innovations goes to the rear mount
