2003 636 Idle Problem - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 2003 636 Idle Problem (/showthread.php?tid=37517) |
2003 636 Idle Problem - Twite - 03-16-2012 Very easy to start, no matter how many times it dies. What I was thinking too.....this is such a drastic problem it leads me to believe something serious is out of whack. 2003 636 Idle Problem - J Blox - 03-16-2012 Seems like it has to be spark or fuel... any timing issues would cause it to not want to start... you changed airboxs? can't remember if the 03/04 has the secondary injectors there.. 2003 636 Idle Problem - Petarded - 03-16-2012 I asked him about this yesterday as I had clogged airbox injectors in my 05... he had checked and swapped that with no luck also...
2003 636 Idle Problem - Twite - 03-16-2012 I'm still leaning towards a vacuum or Throttle Position Sensor problem.....even though I've tried 3 sets! Perhaps I will sneak over to Rowdy's and pirate some parts off his bike!! 2003 636 Idle Problem - ~03~raven - 03-16-2012 Yea I would think TPS too. Or maybe something got snaged on the subharness the connects the TPS to the main harness or a short in the main harness?
2003 636 Idle Problem - Petarded - 03-16-2012 Sounds like a good ideyaaaar 2003 636 Idle Problem - loogie - 03-16-2012 Mine did same thing when I forgot to plug the TPS into the harness 2003 636 Idle Problem - Twite - 03-16-2012 Also logical...but I've tried a different harness and sub-harness. 2003 636 Idle Problem - ~03~raven - 03-16-2012 Do you still have any of the remains of the kill switch hanging out? Had a buddies bike do something similar and thought it was TPS and we checked everything even the FPR and turned out it was a short in the line for the kill switch. Uh-uh man, hope you get it sorted out soon though.
2003 636 Idle Problem - ash-d - 03-17-2012 maybe fuel hose or tank breather hose obstructed ive heard that can cause idle problems and cuting out. |
