08 wr250x Stunt Build... Check it out! - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.the-nags.com/forumdisplay.php?fid=104) +--- Thread: 08 wr250x Stunt Build... Check it out! (/showthread.php?tid=35211) |
08 wr250x Stunt Build... Check it out! - Stubbz63 - 01-08-2012 crank that idle get rid of that decompression breaking that shits horrible, lil idle itll do whoolies by itself lol 08 wr250x Stunt Build... Check it out! - ajbsays - 01-08-2012 ![]() ![]() ![]() red tubing, red chain and sprocket.. custom sprocket. 08 wr250x Stunt Build... Check it out! - Stubbz63 - 01-09-2012 looks good 08 wr250x Stunt Build... Check it out! - ajbsays - 01-09-2012 thanks stubbz, wrap will be all on by this wed! then the only thing left is the dcb and gpr and then some riding time lol! 08 wr250x Stunt Build... Check it out! - ajbsays - 01-12-2012 ![]() side view ![]() closer up ![]() front shroud cut down and wrap ![]() rear shroud ![]() swing arm wrap, bad boyyyy 08 wr250x Stunt Build... Check it out! - SQUINTS - 01-12-2012 Looks sick man. Good work setting it up 08 wr250x Stunt Build... Check it out! - ajbsays - 01-12-2012 thanks squints,, and its way faster then stock with that auto tune,, i know its still a 250 but i had her up to 92 the other day and she was still pulling! 08 wr250x Stunt Build... Check it out! - SQUINTS - 01-12-2012 Damn!!! Hell ya post up some vid! I should have fucked with the one I had before getting rid of it. If I could have hit 92 I would have probably kept it. U get a speedo healer? Or is it reading 92 w that big sprocket??? 08 wr250x Stunt Build... Check it out! - ajbsays - 01-12-2012 i got the speedo healer.. it hit 92 with stock gearing, but i would have hit higher then that i let off the gas, im guessing im still going to hit mid 70s- low 80s with that sprocket... 08 wr250x Stunt Build... Check it out! - R1wonder - 01-12-2012 Syracuse FTP !! |
