How did you learn pulling in the clutch? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: How did you learn pulling in the clutch? (/showthread.php?tid=34627) Pages:
How did you learn pulling in the clutch? - Eerk - 12-14-2011 short coasters to dead stop, straight line
How did you learn pulling in the clutch? - NickLAudio - 12-14-2011 Did a wheelie, pulled in clutch instead of tapping hb. Found myself in a magical yet mysterious coaster. Proceeded to crap pants. How did you learn pulling in the clutch? - Duane S. - 12-14-2011 Quote:
How did you learn pulling in the clutch? - *Joker* - 12-14-2011 Quote:
Fag Drags are the easiest way to join the circle club but I'm not convinced that they teach you anything other than how to look silly during a wheelie. How did you learn pulling in the clutch? - SQUINTS - 12-14-2011 Quote:
How did you learn pulling in the clutch? - beardo - 12-14-2011 I had to make myself do it, I would get it up near bp and force myself to slip it in, it just takes practice. Now im such a clutch whore I doubt I could ride w/o it. Having a super pimp ez pull long lever and then some RSC doesn't hurt either
How did you learn pulling in the clutch? - stunt305 - 12-14-2011 Pulling in the clutch is the easy part releasing and reengaging is the bitch I'm working on now. Good luck. Go out and practice How did you learn pulling in the clutch? - beardo - 12-14-2011 Fag drags teach you nothin' but bad habits that you eventually have to unlearn
How did you learn pulling in the clutch? - Austin913 - 12-14-2011 Quote:
How did you learn pulling in the clutch? - Beto - 12-14-2011 Quote:
