Unicycle f4i build - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Classifieds (https://stuntride.the-nags.com/forumdisplay.php?fid=6) +--- Forum: Wanting to Buy - Parts/Accessories (https://stuntride.the-nags.com/forumdisplay.php?fid=95) +--- Thread: Unicycle f4i build (/showthread.php?tid=34406) |
Unicycle f4i build - kevin09 - 08-13-2026 \r\n \r\n \r\n let me check my garage first lol i have class till about 2 then ill run to my garage and take a peek and see what is all in there and then ill shoot you a pm Quote: \r\n
Unicycle f4i build - Beto - 08-13-2026 \r\n \r\n \r\n $35 shipped\r\n
Quote: \r\n
Unicycle f4i build - maverickxp - 08-13-2026 \r\n \r\n dont forget your gunna need a bad set of forks and both upper and lower triples so that you can mount your handle bars, or at least some tubing thats the same size as the forks\r\n Unicycle f4i build - M.F. Mall Cop - 08-13-2026 \r\n \r\n \r\n I got a set of f4i forks. One fork is good and looks straight. Other fork is missing the outer silver casing but all the internals are there. Get a casing and some oil and ur all set. Id do 50+shipping.\r\n
Quote: \r\n
Unicycle f4i build - SQUINTS - 08-13-2026 \r\n \r\n Just mount up db bars and problem solved\r\n Unicycle f4i build - StuntBikeJake - 08-13-2026 \r\n \r\n \r\n ding ding ding\r\n
Quote: \r\n
Unicycle f4i build - SQUINTS - 08-13-2026 \r\n \r\n \r\n Win\r\n
Quote: \r\n
Unicycle f4i build - maverickxp - 08-13-2026 \r\n \r\n \r\n still gunna need upper and lower triples though unless you bolt db bars to your frame\r\n
Quote: \r\n
Unicycle f4i build - SQUINTS - 08-13-2026 \r\n \r\n \r\n Yep. Triples so u can still "steer" lol Quote: \r\n
Unicycle f4i build - ReCkLeSsRyAn - 12-06-2011 Got the frame motor swing arm and rim for cheap always wanted to ride a unicycle f4i but never wanted to do it To my own bike trying to build this on the cheap cheap since it's gunna get destroyed ![]() Needs: Air box Shock Rubber boots that attach the tbodies to the motor Header Electronics And I'm sure there's for I'm missing but I add later |
