F4i ignition toggle switch HOW TO - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: F4i ignition toggle switch HOW TO (/showthread.php?tid=33803) |
F4i ignition toggle switch HOW TO - CONGO - 01-30-2012 Great! Not a difficult mod, I was surprised how easy and effectively it works. Was skeptical, but no issues at all F4i ignition toggle switch HOW TO - R6stuntSC - 01-31-2012 I had to use a 20 amp 2 prong switch all the 30 amps had 3 prongs and it wouldnt work right but its all good now. Congo you know thomas right? I got his old f4i. Shes all torn apart for rebuild lol... F4i ignition toggle switch HOW TO - CONGO - 01-31-2012 Yeah, I know him. Thats awesome that the bike went to someone that is into stunting! I tried to walk him through this mod. Im not sure why its not working for you, I got the 30amp 2 prong switch and it worked great first time. Others on here have gotten it to work. Maybe try again and use the spare resister and diode that came in the packages, resolder carefully, and use quick disconnect electrical connectors to attach it to a 2 prong 30 amp switch. You definitely got the right diodes and resistors right? F4i ignition toggle switch HOW TO - CONGO - 01-31-2012 oh, didnt read your post right,. So you got it to work then, thats great! what all are you planning to do to the bike during your rebuild? Try to fix that fuel pump priming issue, lol. F4i ignition toggle switch HOW TO - Stick - 01-31-2012 This should be stickied. F4i ignition toggle switch HOW TO - paulie boy - 02-29-2012 nice F4i ignition toggle switch HOW TO - matthunter1448 - 02-29-2012 was just gonna search for this this week thanks! do u by any chance know if i can make it inline so i can use the key or the switch ? F4i ignition toggle switch HOW TO - CONGO - 02-29-2012 Quote:
You could put a switch on any of the wires in between the plug and the keyed ignition to make it so the key wouldnt work without the switch being flipped to on position....
F4i ignition toggle switch HOW TO - CONGO - 02-29-2012 ![]() Dont really know why you would want both, but I believe that this would work for you to be able to use either the key or the switch... depending on which your heart desired at the time . Seems like a pain just for the option of either. I dont really like adding splices where I dont have to if I can help it.
F4i ignition toggle switch HOW TO - matthunter1448 - 03-01-2012 i want to be able to still lock my ignition and ride on the street with my key and not be able to kick my key off and be able to ride with out it for the lot |
