what is this sound - Printable Version
+--- Forum: Automotive (https://stuntride.the-nags.com/forumdisplay.php?fid=53)
+--- Thread: what is this sound (/showthread.php?tid=33459)
what is this sound - Deshi Kicks - 11-06-2011
I don't know man, all I know is my buddy's Jeep does the same thing, gets louder with RPMs, doubles sound when he turns, and just whines like a bitch when he's just driving. Could be the pulleys in your vehicle, won't know until you check it out. I was just saying that since you said your power steering pump was already fucked up, go ahead and change that first and it might fix it.
what is this sound - sikgixxer750 - 11-10-2011
I pulled the serpentine belt off and the idler pulley and tennsioner pulley were both shot. Replaced them, but that still didn't get rid of the noise. I am not gonna buy a ps pump because this one still works perfectly fine just makes a little bit of noise, I will wait for it to fail to do that.
Also the new pulley has an ever so slight squeal every now and again.
what is this sound - Raf - 11-11-2011
I just replaced the PS pump on my 7.3 and it was only $60. Had a mad whine and groan to it but its good now. The problem with diesels is that if the pump goes out, you loose the brakes too.
what is this sound - sikgixxer750 - 11-11-2011
would yours do it just going straight though? Also the ps resevoir has a filter in it. I might try changing the res w/ filter since rockauto has it for 11 dollars.
Yeah it got to the point where i would fire the damn thing up at idle and it would whine. I also heard there is a lucas additive for power steering that helps a lot. I didnt try it because for $60 I just replaced the pump and called it a day.
yea if my pump was only 60 bucks I would replace it as well. The cheapest I found online is around 160 plus shipping. Kinda steep to just get rid of a noise.
what is this sound - Jonas - 11-13-2011
Bimmerforums.com will help you SO much! I owned two e34s, and know a lot about them because of that site. Also, for BMWs, use bavauto.com and pelicanparts.com. thats where I found the cheapest stuff.
Got any pictures of the e46? I prefer the e36, just because it's a more classic look IMO
