03/04 zx6 build with 05/06/07/08 parts - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.the-nags.com/forumdisplay.php?fid=104) +--- Thread: 03/04 zx6 build with 05/06/07/08 parts (/showthread.php?tid=31799) Pages:
03/04 zx6 build with 05/06/07/08 parts - OnEWhEeLNEAL - 08-13-2026 \r\n \r\n And the fun begins. I despise working on bikes already Good luck w the build though homie \r\n
03/04 zx6 build with 05/06/07/08 parts - loogie - 08-13-2026 \r\n \r\n \r\n This...Ive done 2 frame swaps and built like 4 03/04s in the last couple years...I move ritQuote: \r\n
03/04 zx6 build with 05/06/07/08 parts - kevin09 - 08-13-2026 \r\n \r\n \r\n yeah it takes lots of time...more for me since this is the first time iv worked on a kawi hahaQuote: \r\n
\r\n \r\n yeah, and seems like partially building mine with all the help ur giving me Quote: \r\n
![]() \r\n \r\nheres update on what i got done today \r\n ![]() \r\n \r\n ![]() \r\n \r\n \r\n
03/04 zx6 build with 05/06/07/08 parts - kevin09 - 08-13-2026 \r\n \r\n this is how far iv gotten....just test fitting stuff...have impaktech cage and subcage coming....esd rearsets and pegs for the subcage.....si side mounts 7* and some other parts.... \r\nnow just debating whether to get steel frame now or later and also when i should buy the fti dual cal bracket ![]() \r\n ![]() \r\n \r\n ![]() \r\n \r\n ![]() \r\nand my stockpile of tires i got today ![]() ![]() \r\n \r\n
03/04 zx6 build with 05/06/07/08 parts - loogie - 08-13-2026 \r\n \r\n \r\n Nice progress...If you have the coin do the steel frame now, that way you can ride it and not feel like its made of glass and actually be able to chuck it here and there learning new shit.Quote: \r\n
03/04 zx6 build with 05/06/07/08 parts - kevin09 - 08-13-2026 \r\n \r\n yeah i really want one but only way ill get it is if i sell my f4i frame and motor and my 05 636 frame, swingarm and tank then ill have the money and space to do it haha by the end of winter it will most likely have a steel frame...\r\n
03/04 zx6 build with 05/06/07/08 parts - JohnnyRocket - 08-13-2026 \r\n \r\n which rear shock did you use??\r\n 03/04 zx6 build with 05/06/07/08 parts - kevin09 - 09-14-2011 ok so decided to start a build thread since i actually have some parts to work with now also need help with some stuff but ill figure it out hopefullythis is what i started out with. ![]() ![]() ![]() ![]() then some cleaning and work... ![]() ![]() ![]() ![]() finally got some parts in and tossed on the harness ![]() ![]() ![]()
03/04 zx6 build with 05/06/07/08 parts - kevin09 - 09-25-2011 07/08 shock, but i have an 05/06 one that i might put on instead...the red on the 05 shock would go with my theme i think
