Best clutch cable for F4i? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: Best clutch cable for F4i? (/showthread.php?tid=30565) Pages:
Best clutch cable for F4i? - PHOZE - 08-11-2011 I had the same problem. my boy put me on to the '04 600rr clutch cable. these are some before pics with the oem f4i clutch cable. Best clutch cable for F4i? - PHOZE - 08-11-2011 these are after with the '04 600rr clutch cable. it def made a difference. Best clutch cable for F4i? - OnEWhEeLNEAL - 08-11-2011 Like Phoze said the 03/04 600rr cable is the best for the F4i. Its the perfect length for flipped clip ons. My F4i cable would get stuck on the radiator cap cause it was too damn long but you wont have that problem with the 600rr and you wont need zippy ties with the 600rr cable.
Best clutch cable for F4i? - andyVE - 08-11-2011 so 600rr it is ![]() gonna get me one
Best clutch cable for F4i? - Tech2 - 08-11-2011 Im going to try it out- thanks alot for the help! Best clutch cable for F4i? - Tech2 - 08-11-2011 I snagged the radiator cap a couple of times also but once I put the lowers on with no zip ties it changed everything and gave me the wacky clutch operation when the bars were turned all the way right-Hopefully the problem will be solved thanks to PHOZE
Best clutch cable for F4i? - *MeatballStunts* - 08-11-2011 my clutch cable is almost too short with my si adjustables raised up about an inch or so .
Best clutch cable for F4i? - GIL with 1 L - 08-11-2011 I used a 600rr cable on my f4i also.maybe this will help you wheelie that bridge |
