636 bog when hot - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 636 bog when hot (/showthread.php?tid=28009) |
636 bog when hot - -Loco- - 05-27-2011 never rog, always keep it the garage.. yes there are, backside of throttle bodies, its in the service manual, synced them with the morgan carbtune tool ![]() that sounds shitty, any way to check the head for leakage maybe without having to tear it apart? injector cleaner is also on my to do list, havent figured anything out yet.. 636 bog when hot - old man roger - 05-27-2011 another thing you guys can check is your secondary butterflies , if they arent working it will act like a choke which would make the bike run ok while it's cold but run like ass when warmed up 636 bog when hot - MiNi GuineA - 05-27-2011 I sent you the picture from the service manual, the 03-06 zx6r throttle body sync is part of the factory maintenance plan. The capped ports on the front are the access points and the adjustments are Philips heads on the rear of the tb's. 636 bog when hot - ROWDY - 05-27-2011 Thank u sir, Im on it!
636 bog when hot - MiNi GuineA - 05-27-2011 You already have the danger!
636 bog when hot - -Loco- - 05-28-2011 i read somewhere on here about someone cleaned the reed valves, that seemed to help him a lot.. so i did this and also cleaned my really dirty airfilter, lol havent rode the bike yet but i'm about to go out for a sesh so i let you guys know if this helped when i get back! also bought some injector cleaner that i will be adding to my gasoline... read good stuff about those products.. 636 bog when hot - -Loco- - 05-28-2011 bike runs mint again! injector cleaner ftw i think
636 bog when hot - MotoDoc - 05-29-2011 dirty air filter will do this
636 bog when hot - BOYD - 05-29-2011 newbies
636 bog when hot - JohnnyP - 05-31-2011 What kind did you use? |
