04 636 cam chain tensioner causing a bog ? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 04 636 cam chain tensioner causing a bog ? (/showthread.php?tid=27424) Pages:
04 636 cam chain tensioner causing a bog ? - jbstunt69 - 05-10-2011 Thanks for the help/input guys, ordering a ape cct tonight from the ape site. Gonna keep my fingers crossed that this also helps with this bog issue. ![]()
04 636 cam chain tensioner causing a bog ? - loogie - 05-10-2011 had the same problem on my 636 i had a few years back,if you remember i posted a thread..in my case it ended up being a tired motor that burned a little bit of oil then alot then blew up at the lot overheated on a limiter burnout ![]() fresh motor solved the bog
