List of 03-04 636 mods - Printable Version
+--- Thread: List of 03-04 636 mods (/showthread.php?tid=22848)
Pages: 1 2 3
List of 03-04 636 mods - StuntBikeJake - 01-26-2011
Originally Posted by navajowalks
Swing arm conversion would be another good topic
And on that note hohey does makes a spacer to use 05/06 wheels on a 03/04 swing arm
Visit hoheydesigns.com
Or use the 03-04 spacer and the front wheel spacer off an 07-08
List of 03-04 636 mods - 1997f3 - 01-26-2011
List of 03-04 636 mods - navajowalks - 01-26-2011
Still have to space out the calipers to the rotor....
Hoheys kit comes with everything to do it right...
Spacing works out just fine... My boy E.T. runs it that way.. as does Payne in OKC.. Payne even runs it that way with the hohey bracket
List of 03-04 636 mods - bojangles - 01-29-2011
or if you want to run the 05-06 wheel and 03-04 swing arm with a FTI bracket Bill makes a spacer for the rotor so you dont space the calipers.
List of 03-04 636 mods - navajowalks - 01-29-2011
You have to do something to put the calipers in the right spot for the rotor on the newer wheel. Trust me I got every year wheel spacer and every year wheel in my garage right now... the rotor on the 03 wheel is way closer to the swing arm than a wheel off a 05/06 or 07/08 which even very by 2mm between those yeares too. I don't want to just rig mine up to work, I'm sure it can be done with out the hohey kit, but you still need to space out the calipers.
Or the rotor.... lol
List of 03-04 636 mods - old man roger - 01-30-2011
i made a spacer for the rotor when i switched to the 05 06 wheels too , it seemed better than making spacers for the caliper
List of 03-04 636 mods - OnEWhEeLNEAL - 01-30-2011
Here's something I copied from SL I think. It's to add a mountain bike adjuster thingamij so if you wanna flip your idle instantly from stock to i dunno 2 or 3k then instantly to 5 or 6k for faster no handed shit then up/down/whatever - you can do it all at the flip of the lever and be accurate with regards to what the idle is set at each time you flip the lever for each different trick. Just be careful with where you put it because if you kick it on accident you most likely will get fucked up. And if you're just learning you probably dont need this anyway but just figured I'd post it up for those who havent seent it since I did.
Here's some important notes and pics I copied from the thread.
List of 03-04 636 mods - nags - 04-21-2011
Originally Posted by Duane S.
smart man they should do this for every bike
NAGS Sticky this buddy
Done
List of 03-04 636 mods - BNasty - 03-08-2012
I have a pic of my 04 636 with the 05 swingarm convertion but dunno how to post it, <-- newb
