how did you get used with using the handbrake? - Printable Version
+--- Thread: how did you get used with using the handbrake? (/showthread.php?tid=21028)
how did you get used with using the handbrake? - raynice - 11-29-2010
just put in work is the only way!!! keep using it and u will get use to it..
lol now i have only 8 more post b4 i get into the classifieds
how did you get used with using the handbrake? - oemsrt4 - 11-29-2010
I used to jump from clutch to hb and always just stall the bike out when I would start to lose a circle. Then my starter relay box took a number two and I bump started my bike for a couple weeks. You learn to coordinate hanging on and working clutch and handbrake real fast when the punishment for failing is pushing a two wheel tank back to life lol. Smash your starter fuse and give it hell man...
Those spring hand exercise things are a good investment too, constantly squeeze those and your hands will turn into death griping stunt claws.
how did you get used with using the handbrake? - Cjones - 11-29-2010
move your levers so that its comfortable. Post a pic of you hb setup?
I started with seat stander, one finger on each.
how did you get used with using the handbrake? - chino12 - 11-29-2010
agree with you guys that ss is the most comfy for hands and my left foot is on rear peg
oemsrt4 that some funny shit you said there
i have to go to my van for a pic, i will post it later - btw hb lever is at the lowest position
how did you get used with using the handbrake? - big ben - 11-29-2010
i worked one for a month straight and got tennis elbow for it....helped a little but not enough, even when i was doing thousands of reps a day
how did you get used with using the handbrake? - Talen - 11-29-2010
By no means am I a good rider, I make (the best Rad Supports on the market though) but, when I have free time I ride around the neighborhood sitting highchair and using the clutch/handbrake to slide, stalls, burnouts and just basic control of the 2 levers there.
how did you get used with using the handbrake? - keshon - 11-29-2010
i just started doing seat stander wheelies and ran with the bike when i did it wrong. crashed a couple times but i got it eventually
how did you get used with using the handbrake? - Austin913 - 11-29-2010
by never using the foot brake. and now, I can't get used to using the foot brake.
