Pegs :) - Printable Version
+--- Thread: Pegs :) (/showthread.php?tid=20290)
Pegs :) - ScarryJerry - 11-09-2010
bike was stunted out lot and street bike. dont have a truck. im gunna buy a street bike and completely stunt this one out. it is leaking oil and a plugg popped out. when i started it after i through it in the suv and got it home it spit oil everywhere. gotta tear it down and figure the problems out. but yea need to buy a bike for the street only.
Pegs :) - $Evan$ - 11-09-2010
prolly put a hole in the stator thingy or whatever its called.
i was guessing temperature plug got pulled out by the cage when it bent cause it bent pretty bad. luckly frame looks good no frame mounts broken.
where the fuck was the oil coming from? did u lose your oil cap? it wouldnt spit oil out for now reason. again did u loop? did u have a cage on?
yea sorta and yea cage. well it went rolling left to right shouldnt be too bad. the plug is where it is coming from. i think the bottom cage bar hit it busting it out of somewhere. but havent looked at it too much yet still sore. gunna streetfighter it so i can do street rides with it. and bent my front wheel (rim).
the plug on the bottom where you drain ur oil from or where u fill it? ur drain bolt might have wiggles loose causing that to happen. tighten it good to go. how fucked is ur rim?
Pegs :) - lee majors - 11-10-2010
run at least 30 psi in the front wheel to keep it from bending during a crash
Pegs :) - ScarryJerry - 11-10-2010
was running 38 psi cold its not too bad of a bend.
Pegs :) - $Evan$ - 11-10-2010
hhahahahaahahahahahaha!!! that was awesome. ur go pro kept filmin and everything!!!! glad ur ok dude!
Pegs :) - Cjones - 11-18-2010
Originally Posted by GIL with 1 L
if you run bmx pegs i suggest you find something to fill the hole . the edge gets sharp after a while from being thrashed , my friend went down once and filled the whole inside of the peg with meat from his leg
Holy! but yeah makes sense
