bike wont start - Printable Version
+--- Thread: bike wont start (/showthread.php?tid=20135)
bike wont start - P-ham - 11-04-2010
im starting to think its either my stator or rectifier like alex said
bike wont start - ALEXD - 11-04-2010
It should be rectifier first before the stator and I would just buy a rectifier first before you even get a voltage meter because your bike isn't running anyway so just put your money towards the part you need but that's just my 2 cents
bike wont start - old man roger - 11-04-2010
you can get a voltage meter for 3 bucks from harbor freight , buying parts on a guess gets expensive ..
bike wont start - P-ham - 11-06-2010
so i took the rectifier from my other R6 and put it on and it still didnt start so im thinking its not my rectifier now its probably my stator or a loose connection. i tested one of the relays with the light and it blinks instead of a steady light. what should i do?? im about to go tear off that stator
bike wont start - old man roger - 11-06-2010
if you arent going to check the voltage then you might as well just put a bunch of guesses in a bag and draw them out one at a time .
putting a regulator/rectifier from another bike on wont tell you any thing if your battery is dead .
bike wont start - Ethiopian - 11-06-2010
some people dont know how to opperate those voltage things. i dont even know what they look like
ok then here goes volt meter 101 , get a 3 dollar volt meter and set it just like the one in this picture
if you put the end of the leads on your battery you can tell what the voltage is , red on positive black on negative
no more excuses
bike wont start - sc0braj - 11-06-2010
did you push start it and let it run for a while after you put on the other rectifier?
I always wondered why black is negative ? whoever decided that was racist lol.
bike wont start - i_throw_nickels - 11-06-2010
check to make sure all the cable are tight too
and no corosion
