MSR Vs. RSC......What's ur vote? - Printable Version
+--- Thread: MSR Vs. RSC......What's ur vote? (/showthread.php?tid=19089)
MSR Vs. RSC......What's ur vote? - GIL with 1 L - 10-06-2010
I like my Msr. I have tried the rsc and found that its not for me. I can see why so many people rave about the rsc. If you don't like it send it back. There are shortcomings in both designs. Its like Ford vs Chevy
MSR Vs. RSC......What's ur vote? - i_throw_nickels - 10-06-2010
Originally Posted by Endo Andy
I've had both levers. The msr worked fine until it got very sloppy and loose. The adjuster always stripped out as well as the pull angle adjuster. I was pissed when that broke while attempting to install it.
Anyways ive run just about every type of clutch lever, given I am far from a pro rider I still prefer the RSC.the adjuster is awesome and there is very little if any slop between the lever and perch. And its even got a nice little hooked edge so your finger doesn't slip off the end.
Big Rik, I had the same problem at first but after I adjusted the cable it was fine. Ive got a clutch arm modded f4i. You didn't mention what you ride. Why don't you share?
mine did too RSC ft(mufuggin)w and no way msr should even be compared to RSC. MSR made my bike shift like poop sometimes bcuz it was sloppy. New joint = HOTNESS
MSR Vs. RSC......What's ur vote? - Teach - 10-06-2010
best reply on here.
i've had same drag and engagement issues but i love the quality. currently trying to new bushing as well as the clutch arm mod.
josh has been very helpful and accomodating during all of this.
will post up my results when its done, hoepfully next week.
MSR Vs. RSC......What's ur vote? - old man roger - 10-06-2010
Originally Posted by Teach
best reply on here.
the clutch arm mod and any easy pull lever do the same thing..
by increasing leverage you also increase the distance the level will need to move to disengage the clutch so if you are having an issue with the clutch disengaging you dont want to increase the length of you clutch release lever..
the rsc is the best easy pull on the market and teach there are two m's in accommodating
MSR Vs. RSC......What's ur vote? - Big Rik - 10-06-2010
Awesome replies everyone. I'm gonna give RSC a shot and see what's up. I currently ride an F4i.
MSR Vs. RSC......What's ur vote? - GIANT DOUCHE - 10-06-2010
i had the msr. it worked fine. but i just got the rsc n this thing is beast.
lol i hate you! typing quick...interesting, i'm going to try some things anyways. clutch on RR is weird
MSR Vs. RSC......What's ur vote? - TheFBomb13 - 10-06-2010
Originally Posted by Big Rik
Nick, this was from someone informing me on RSC. It was interesting.
Its a great lever but its still got some flaws that need to be worked out. I spent $100 on a lever that was not designed to accommodate everyone such as people with longer fingers and now I am supposed to spend $15 on a spacer???? I made my own spacer and I am still having issues. The clutch does not fully disengage, its dragging slightly when I do coasters, when i pull the clutch in the front end comes down. I have adjusted the cable AS BEST as possible, now my clutch slips when I drive on the road(still drags when its in). My first complaint was when I adjusted the cable the way a clutch cable is supposed to be adjusted (1/8-1/4" free play) the clutch would start to grab 1/8" from the bar. This sucks for double fingering the clutch and brake and when your finger gets tired, you physically cant pull the clutch all the way to the point where it disengages. apparently this is only an issue with some bikes, I dont see how thats possible, both the RSC's we bought are like that. If you read the RK ARMOR hate thread, there are some other people complaining. Again, I cant bash it, its a wonderful lever, but the geometry still needs some tweaking, no big deal, but he doesnt want to do that. He even admitted that he gave it more leverage and in this situation, when you give more leverage, you are take away overall cable pull, another reason why the clutch grabs at a different spot and drags. Its your call. The MSR works fine, personally I would stick with that, shim the lever in the purch to take some of the slop out, or if you know someone at a machine shop, give them an MSR and have them make an exact replica but with a bronze or delrin bushing. I only replaced my MSR because I wanted a precision lever. I was using the same MSR for almost 3 years and never broke one. Another alternative is get the MSR AOF lever, its a way better quality lever than the EZpull, but then you have to do the clutch arm mod. You can do it on hondas, not sure about the other bikes like kawi.
you just don't know how adjust your clutch bud.. my friends was the same as your cause he didn't know better.
i seen a few people that had the clutch mod done to their bike and didnt know it because they got the bike already set up , could be the case with that guy
