Cheap kawi frame neck reinforcement - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: Cheap kawi frame neck reinforcement (/showthread.php?tid=18442) |
Cheap kawi frame neck reinforcement - JohnnyP - 09-15-2010 Yes that will be a serious pain in the ass to weld, because the foam will contaminate the weld... Im not sure if this is a good idea Cheap kawi frame neck reinforcement - Lit - 09-15-2010 ya, that probably would suck. were find out i guess maybe if i wouldnt of been a cheap fuc and got reinforcements welded on first then it wouldnt bee so bad. Cheap kawi frame neck reinforcement - JohnnyP - 09-15-2010 Trust me I had a swingarm that needed welding done to it, and my welder had a hell of a time trying to weld it because it was filled with foam like yours...The foam kept melting and contaminating the welds. Didnt want to penetrate and was just making a mess. Some swingarms come filled with something similar and others have rubber injected into them... Cheap kawi frame neck reinforcement - Talen - 09-15-2010 Its non-flammable, wont burn. May melt. This aint "Right Stuff Foam" from Home Depot. Cheap kawi frame neck reinforcement - Lit - 09-15-2010 Ill hit a piece of foam with a torch in a mintue and see if it Burns,melts or what to assume what will happen Cheap kawi frame neck reinforcement - Lit - 09-15-2010 Ya just like a 1000rr swingarm, your absolutely right. Maybe this willjust be a good idea for street bikes Cheap kawi frame neck reinforcement - Naarden - 09-15-2010 They do this is Uni-body drift cars and have had good results Here is a write up about it http://octanereport.com/tech/parts-r...tiffening.html Cheap kawi frame neck reinforcement - JohnnyP - 09-15-2010 I think it could be a good idea in terms of adding strength to your frame, you just have to test it out and see...Its not good for welding thou, if you ever have to do any. Cheap kawi frame neck reinforcement - Doodle - 09-15-2010 eh..dont know how much strength FOAM is going to add..fill'er up with some liquid steel,jb weld type shit..would add a lot of weight but im sure it would have less flex Cheap kawi frame neck reinforcement - Ethiopian - 09-15-2010 this is awesome mike, can u fill my f4i frame? |
