636 choke mod explained - Printable Version
+--- Thread: 636 choke mod explained (/showthread.php?tid=15543)
Pages: 1 2 3 4 5 6
636 choke mod explained - loogie - 06-17-2010
why not leave choke cable hooked up stock to the signal switch housing and activate it like that??? on a side note...sandbox at NDC customz is supposedly designing a "idle box" contraption that essentially does the same thing..adjusts your idle in stages like 1-5 or some shit...
636 choke mod explained - SKETCHY - 06-17-2010
Ask OMR, he did something like this.
636 choke mod explained - Zack Z - 06-17-2010
Quote Originally Posted by Ethiopian
borne had his choke rigged up on his left clipon like ur talking about, maybe pm him.
Quote Originally Posted by SKETCHY
cool i will pm them
because the stock housing is soooo big...i want something with a much lower profile so i don't get my feet hung up on it
636 choke mod explained - SIC J - 06-17-2010
I know Shin can instantly switch from one idle to another. Saw him installing it at XDL Daytona. E-dub or Apex might be able to give some insight on this as well.
Quote Originally Posted by SIC J
thats exactly what i'm going for
636 choke mod explained - old man roger - 06-17-2010
you can spread the adjuster further apart to get more idle out of it , i added a spacer under the spring and i know tony prez made the roller part bigger for the same effect ..
another way to get it to idle higher would be to drill a couple small holes in the part that moves when you turn the throttle and bolt a plate to it so the roller can push it further ..
seen one guy use a ten speed bicycle gear change lever , they have notches so they stay where you put them ..
636 choke mod explained - Zack Z - 06-18-2010
thanks roger for the help! i put a bigger roller on and took the shifter off my old mtb...it works perfect!
636 choke mod explained - paragus - 06-18-2010
Quote Originally Posted by Zack Z
take a pic??
636 choke mod explained - loogie - 06-18-2010
+1 on the pics...better yet post a how to thread in case anyone else wants superidlewhore mod....lol
