$85.00 Secondary (Dual) Caliper Bracket 03/04 636 - Printable Version
+-- Forum: Classifieds (https://stuntride.the-nags.com/forumdisplay.php?fid=6)
+--- Forum: For Sale - Parts/Accessories (https://stuntride.the-nags.com/forumdisplay.php?fid=15)
+--- Thread: $85.00 Secondary (Dual) Caliper Bracket 03/04 636 (/showthread.php?tid=14691)
$85.00 Secondary (Dual) Caliper Bracket 03/04 636 - Dubb - 05-21-2010
I'm working on a promo vid right now should be up in an hour or so
$85.00 Secondary (Dual) Caliper Bracket 03/04 636 - StuntBikeJake - 05-21-2010
Originally Posted by ADBZ Matt
I do the same with mine... I guess i dont fully understand your question, but the bracket is snug to the center axle keeping it the exact same distance from the rotor at all times... when you adjust your wheel using your stock spacers the bracket moves where you put your spacers...
Hope this answers your question??
I guess a better way to ask, is the stock adjuster plate required or could you just use the bracket? (for people like us that use feeler guages)
Soon available for 05/06 and 07/08 swingarms???
To answer the first question I ride the 07-08 zx6r now and yes it fits the same
Yes you still need to use the stock adjuster bracket only becouse they are seprate but they still work off of the axle so it's the same adjustments
Thanks man spread the word.
Sorry for all the questions.. but one more just popped into my head
What is the thickness of that bracket??? 1/4", 1/8"?
That is why I was curious about still using the stock adjuster.. I personally would rather have it made of thicker material and eliminate the stock adjuster just for piece of mind and durability...
$85.00 Secondary (Dual) Caliper Bracket 03/04 636 - A.TEK - 05-21-2010
Originally Posted by OnEWhEeLNEAL
From what Ive read pretty much all radial calipers have the same mounting points so you could pick up almost any radial caliper. I'll let someone else confirm that but I remember reading that in something Bill from FTI posted.
dang, ive started a fabrication trend lol, yes neal, all radials have the same mount points, BUT NOT ALL RADIALS HAVE THE SAME SIZE 'FEET'. well, i call it the 'foot', where you put the bolt through to mount to your forks
FTP, yeahwith slimmer steel u worry about bending under force, i use a cold-rolled aluminum block, it still affords for a much higher tensil strength then hot-rolled. the design here, if you use a gauge to measure spacing then you would no longer need the axle block, it just would keep the nut from moving because there will be a gap from the nut to the lock pin
not to thread jack, but if you take a look at mine, not sure if you can see but the adjustment lines are already marked and scribed, if you have a simple hole in your bracket and use the oem piece over it then ur not getting a precise adjustment but not enough to make a difference
Yes it can be made thicker it is made of 1/4 in now but can easily be made thicker to replace the adjustment block.
$85.00 Secondary (Dual) Caliper Bracket 03/04 636 - Chadf - 05-23-2010
Works like a champ!
